No don't say it, No don't say it, No don't say it, No don't say it, No don't say it, No don't say it, No don't say it,
Anybody use JR equipment.......
Re: Anybody use JR equipment.......
Perhaps it is Horus then
- Ian Davis
John
On the presumption that the XG is the same as my DSX9 regarding switch positions and functionsI might be able to help.
From your description I presume you want flaps on their own and then crow for landing. After many hours of following various setups from the web none of which worked I discovered a solution that works.
Send me your e-mail address by PM and I'll try to define the setup I've used.
Anything to keep you away from Taranis.
Ian
Ian
John, I have an XG 11 TX, I previously used the DSX9. Firstly do you have an XG manual ? If not download one from the JR Mcgregor web site. The XG has a fair number of additional functions (over the DX9). One big difference is the ability to allocated a channel (as shown on the MONITOR screen) to a RECEIVER output channel using DEVICE select. See page 90, 91 of the manual. Now be careful if your going to use a particular function you need to set the "OUT" to INH, then set the DEVICE to particular switch or lever you wish to use.
I fly large sale vintage gliders, ASK18 at 5.3 mtrs nearing completion now. Flaps are not required, so I use the 3 position rudder switch using channel AUX 8 with DEVICE set to RUDD SW plus FLAP set to RUDD SW with the FLAP channel set to INH.
If you send me a PM with your email address I will try to help a bit more.
Clive
Clive
Or, you could get a Taranis, and do the job properly.........
- Ian Davis
Well done John. JR redeemed.
Happy new year
Ian
Happy new year
Ian
