3 pin equivalent to MPX 6 pin
Looking to make a plug in connector for a single servo in the outer wing panel, is there anything out there which is effectively a 3 pin version of the MPX 6 pin plug? thanks.
- terry white
Re: 3 pin equivalent to MPX 6 pin
Hi Frank, is the 6 pin too big for the application? If not could you not just use three of the 6 pins, or am I missing something?
Regards Ter.
Regards Ter.
Use factory servo connectors.......female on the power side and male on the servo side. There are companies that sell the cases, pins, and crimpers.....I use them on everything.....my 1/2 scale Ka6 uses them for the elevator/stab halves and the main wing tip panels use them at the joint.
Thanks, the MPX ones look like they would be most suitable. I hadn't thought to look if MPX did them in other configurations than the 6 pin
