New frsky rx
Re: New frsky rx
Oh Barry, you really are quite the fisherman...
- Andrew Ray
Re: New frsky rx
I have just had a couple of these G-RX8 receivers turn up today and noticed that the unshielded end of the aerial is 23mm whereas on my other FrSky receivers, X8R, S6R, S8R and V8R7-II the unshielded length is 32mm. A quick search shows the length should be from 29mm to 32mm.
I am a little concerned as presumably this will reduce sensitivity and thus range, does anyone know different?
Re: New frsky rx
The antennae are almost certainly intended to be 1/4 wavelength & this is 31.5mm at 2.4GHz.
Thus the 32mm length is probably correct and the 23mm ones wrongly cut (unless FrSky have a corresponding matching circuit inside the receiver).
Best to check with FrSky & see if a replacement is needed.
Re: New frsky rx
I have asked, but they are on Hols next week, so it may take a while.
- Andrew Ray
Re: New frsky rx
Thanks for the replies, seems patience will be the order of the day.
Re: New frsky rx
It seems that the shorter aerials are good. This received this morning:-
Barry, do not worry, it is not problem. The antenna is correct, after strict testing and is matched to the hardware for best length.
So there we go then.
- Andrew Ray
Re: New frsky rx
Thanks Barry
Re: New frsky rx
Mark,
The 9mS frame rate is only safe for digital servos, there is a firmware update for 18mS for analogue servos
Re: New frsky rx
Yes, and no in that order.
You are welcome to visit, but leave it till next week, as I have some dreaded lergy at present.
Re: New frsky rx
You have a virus and you're on the net........!!
