3 pin equivalent to MPX 6 pin
Posted: 29 Apr 2017, 07:16
by FrankS
Looking to make a plug in connector for a single servo in the outer wing panel, is there anything out there which is effectively a 3 pin version of the MPX 6 pin plug? thanks.
Re: 3 pin equivalent to MPX 6 pin
Posted: 29 Apr 2017, 14:33
by terry white
Hi Frank, is the 6 pin too big for the application? If not could you not just use three of the 6 pins, or am I missing something?
Regards Ter.
Posted: 29 Apr 2017, 14:45
by Tom Pack
Use factory servo connectors.......female on the power side and male on the servo side. There are companies that sell the cases, pins, and crimpers.....I use them on everything.....my 1/2 scale Ka6 uses them for the elevator/stab halves and the main wing tip panels use them at the joint.
Posted: 01 May 2017, 20:41
by FrankS
Thanks, the MPX ones look like they would be most suitable. I hadn't thought to look if MPX did them in other configurations than the 6 pin
