Cheap wing servo connectors
I have just discovered these on eBay I do not know if anyone has any experience with them or not??? They are 24 pin mini atx connecters for less than £4 . . I plan to cut them in two to make two pairs of 10 pins for a 3 wing servo set up. The pins look the same has normal servo pins. Has any one used them??
Re: Cheap wing servo connectors
Roo
It may be the photos but the pins do not look glod plated. If they are not then they could tarnish quickly and cause problems.
hi these are not gold pins but I have just tried them and they are not getting a good connection on some of the pins. so will go in bin. ROO
- terry white
Hi Roo, I used them a long time ago. The bin is definitely the best place for them.
