can anyone help. I'm just starting a 1/4 scale harbinger and the plan has no CofG, no datum line, no incidence angles and no control throws!
CoG is the important one. I shall plump for strut position/ wheel axle, if no-one has any experience with this prototype.
here's hoping,
Phil sellwood
harbinger data
Re: harbinger data
Hi Phil when I had one it balenced bangon the wheel and flew very well on it. Cannot remember the control throws.
Re: harbinger data
Phil,
Full size control throws are on the attached BGA data sheet.
As long as you have enough then you should be able to fine tune from there.
- Attachments
- Harbinger BGA data sheet.pdf
- (107.5 KiB) Downloaded 99 times
Re: harbinger data
hi guys,
thank you so much for the info. I haven't started the build yet but it's nice to have an idea of where it balances so the radio can hopefully go where I want it not where it must go- hate using excess lead!
Phil.
Phil.
