Schleicher ASH31 4m
Re: Schleicher ASH31 4m
Once I've layed the top spar cap in, I'll then bond in a shear web as I did with the elevator, then bond the bottom spar cap to it.
Hi Martin,
I wondered if you'd considered using pultruded carbon strip rather than laying up your own using tows? Something like this...
https://www.hyperflight.co.uk/products. ... rbon-strip
or here..
https://carbonfibreprofiles.com/index.p ... cts_id=629
The benefit would be that the strips would be stronger and more uniform than hand-laid tows, due to a higher fibre/resin content and most importantly that the fibres are much straighter and more aligned.
I think the main drawback of hand laid tows is that the vast majority of them are twisted or wavy (even if only slightly) with the result that they do not evenly share the tensile stress. When the spar is loaded, the tiny minority of straight strands find themselves having to accommodate a stress that was designed to be taken by all the fibres in the spar - so they fail and pass the stress onto the next wavier strands...which fail etc and then whole spar fails. A pultruded spar on the other hand contains very accurately aligned fibres due to the pultrusion process, so that when it's loaded they are much more likely to share the stress across the whole crossection of the spar.
Added to this, hand-laid tows will probably include imperfections like air bubbles and specks of foam etc which will act as stress concentrators and further points of failure.
I hope this doesn't sound negative Martin, I'm just offering it as a suggestion....
or here..
Hello Rog,
Your suggestion is very welcome. I have & do use those pull-truded strips, particularly on shorter lengths, like tails.
My reasoning for using tows on wings is the ability to achieve tapered spar width and depth. Granted the layup and bond won't be as good, however, I tend to over engineer the amount of tow.
I will also cure under vacuum which should reduce the risk of voids, etc.
So far I've never had a spar cap failure (kiss of death ), de-lamination/buckling of the skin seams to occur first (& never in flight), although I don't fly my models in the alps!
Here is the first inner wing section after spar cap has been bonded in (under vacuum). For this stage I used perforated film and kitchen roll, to absorb excess resin (& distribute vacuum).
I've added a 48gsm leading edge strip & an 80gsm bias D box.
The spar cap top is below the wing profile so I will now fill and shape, before adding the final carbon skin.
Note the added foam end blocks to stop the tows wrapping over at the ends.
Left hand inner wing section now in the bag, to cure the upper spar cap and d-box.
Weighted down using the profile negative and my old gym weights (long since used to improve muscle tone )
Elevator at the back with filler skim, to fill pin holes
The mid section wing joiner are assembled and bonded (with spots of 5min epoxy).
10mm carbon rod, joiner tube previously formed over it then cut into 4.
5mm carbon location pins into brass tubes
Good progress Martin. Just perforated film and kitchen towel is the way I want to go in future; no more Mylar nonsense.
When you get to applying the full skins I suggest you weigh down the trailing edges with a straight bar to prevent them curling. I make an MDF board for - and the shape of - each of my cores to put between them and the weights to spread the load evenly.
For the outer skin, I think I'll try a test bagging with perf-film (on a sample profile), not Mylar. I'm a little worried about that trailing edge.
1 piece of MDF makes sense Kenneth - i have tended to use some flat pieces of oak, of various sizes, to spread the load, but just for bagging the outer skin.
Top side of the elevator has been filled and sanded, then 3m putty applied & sanded again (it's good stuff, fills small imperfections really well - BE WARNED, it melts foam).
A light coat of primer was sprayed on, still small areas needing attention.
Countersunk fixing hole also added.
