Hi
I am looking to build a Salto and was looking at the PT one, could somebody tell what the wingspan is for this model?
Rob
Pat Teagle Salto wingspan
Re: Pat Teagle Salto wingspan
Rob,
I think that you will find that it is 3.4m as it is a 1/4 version of the 13.6m full size variant.
I can double check my drawing to make sure.
Hi Peter,
Thanks for the info, just wanted to make sure I could fit the wings on the building board. As long that is less than 4 meters it will fit!
Rob
Rob
Rob,
No problem then as the Salto was a shorter wingspan as it was designed s a out & out aerobatic glider.
A full 15m standard class is only 3.75m, so plenty of possible subjects will fit.
You should worry - my current project has 50mm to spare across the room
