Swallow seat
GlynM
Swallow seat
Post by GlynM »
Evening all! I’m coming to the end of the building the Tony Slocombe Type 45 swallow -1/4 scale , I’m struggling to find any pics to make the cockpit seat , if anyone can help I’d really appreciate it .
Re: Swallow seat
This is all I have!
GlynM
Re: Swallow seat
Post by GlynM »
Thanks Cliff!
GeeW
Re: Swallow seat
Post by GeeW »
GlynM
If you need any specific Swallow shots just ask as I will be working on one in the next couple of weeks. Hoping to get it flying for the first time in quite a while.
Gordon
Re: Swallow seat
GeeW wrote: 20 Oct 2023, 15:50 GlynM
Gordon
Is that not what was designated the Swift? Different canopy to the earlier Swallows. if memory serves me correctly it was later Swallows that used the Dart canopy and was designated "Swift"
early canopy
GeeW
Re: Swallow seat
Post by GeeW »
'CAX' is definitely a swallow. The 'Dart' canopy was 'as standard' on later production Swallows and has also been retrofitted to many of the surviving earlier Swallows.
T.45 Swallow flight manual front page.pdf
(1.53 MiB) Downloaded 58 times
Re: Swallow seat
Hmm. I thought that when the canopy was changed, they changed the name to Swift.
GeeW
Re: Swallow seat
Post by GeeW »
As on all production aircraft there are lots of details that are changed during the run.
Notably on Swallows
Rudder pedals, early ones are bottom hinged, later changed to top hinged and adjustable
Trim levers ..I have seen three types fitted so far. As in the above image seems common but also sometimes mounted much higher up. I have also seen one example with a K-13 type assembly also mounted higher up.
Trim tabs, most seem to have one but one of the examples at the VGC 50th bash also sported a second tab on the other side set up as an anti-servo tab.
Canopy lock, those that started life with the small bubble canopy have one style where as later (dart canopy) version have a different set up.
Air brake handle either as just about visible in the image a couple of post up from this or as below
GeeW
Re: Swallow seat
Post by GeeW »
Will be hopefully working on the Swallow later this week. If anyone would like any specific images please let me know and I will do my best to oblige?
Gordon
Re: Swallow seat
Always good to have photos, I would be grateful for any and all you may take. You can email them directly to me if you wish.
