Hi Folks
Has anyone got a spare glassfibre fuselage? - approx 1:4.5-1:5 scale - thats about 1.4m long (including rudder) - 1:4 scale is too big.
Its for an ancient Robbe ASW19 kit I picked up recently in an auction lot - 3130mm span "semi-scale". The fuselage is "Plura" - ABS plastic type material - unfortunately not usable as it has gone very brittle with age - I cracked it just cleaning it. Before I try covering it in glass cloth to strengthen it - big messy job - I thought I'd see if anyone has anything suitable to replace it. Something that needs some repair would be fine.
Doesnt have to be an ASW19 - any "modern" style glider would do - T-tail or low set - its gong to be a "semi-scale" anyway.
Phil
Wanted - glass fuselage - 1:4.5-1:5 scale
Re: Wanted - glass fuselage - 1:4.5-1:5 scale
I have a Pat Teakle Pik 20 fuse taking up space in my garage, inc wings, tailplane, rudder, but no wing joiner!
Is that any good?
Colin
Is that any good?
Colin
Thanks Colin - but too big at 1:4 scale
maybe put it up on a separate ad & someone will buy it !
Phil
Phil
