Hmodel ASH 25 Mi
- Antonia
Re: Hmodel ASH 25 Mi
May be a bit late but Happy New Year to you ASH 25 lovers
Nice work Christian, very nice Is it you at the bottom of the news page on the streifly web page? What a great job you have......
How is the progress with your electrics going Eric? Hope you are feeling much better now.
Regards, Antonia
Regards, Antonia
They look great Christian - nice one! By the way, did you build another Nimeta after the first one had the accident?
@Mike: it was an Major repair.
From the first one we only used the
vertical fin,the Engine, the framework with the controls and the Winglets.
We Build an new fuselage and the Wings are from an eta- so 2 fuselage and 1 pair wing.
@ Eric: can you give me the weight of your elevator?
I think my elevator is a Little bit heavy-
So i think about Build an mold of it and Build
An new one with CFk.
Regards Christian
Regards Christian
Hi Antonia, Progress is slow at present. Gradually feeling better and I'm slowly getting my strength back. Still acquiring all those little bits and pieces that I keep finding I need to finish the 25.
Hi Christian, Sorry about the delay in getting back to you with the weight of the tailplane, mine weighs 198 grams.
Hi Simon, Bother, you'll be able to keep an eye on my progress now!
Best regards
Eric
Best regards
Eric
I've just been doing some calculations for the up and go motor electrics and have found using Ecalc, that the AXI 4130/16 fitted with an Aeronaut 14x9 four bladed folding propeller will draw from the 7S battery arrangement, via 10 AWG cable, just on 60 amps which is the maximum allowable current for the motor.
If I go to 6S then there's not enough power to take off and with 8S there's a possibility of inadvertently burning out the motor if I let the current exceed 60 amps. However I will have telemetry to monitor the current being drawn by the motor and hopefully my co-pilot will keep an eye on that for me!
Originally I was going to use XT-60 connectors but after running Ecalc I have now decided to upgrade to EC5 and XT-90 connectors which are both good to 90 amps.
I have also learnt that using a 7S battery, that I will need to include an anti- spark arrangement to save any damage to the connectors or the very expensive ESC - however this is quite easy to achieve with a small link and momentary switch or I could use the ready-made XT-90 anti spark plug and socket arrangement.
Will do - Thanks for that useful piece of info Simon.
Re: First Flight ASH 25 Mi
Hi,
Last Saturday the 25 flys first time-
All Systems working great!
First Start with aerotow
Second start self launch with the sls.
At Last Time i spend some work for more
Scale Details like bugwiper,new Panels
and Second Pilot.
Regards Christian
and Second Pilot.
Regards Christian
- Antonia
Congratulations Christian, she sure looks beautiful. How did sls launch go? Was there any tendency for her to nose over until the elevator gained authority?
Antonia
Antonia
Hi Antonia,
I need 3 attempt.
The probleme was that the elevator deflection was too little,
the grass was weak and damp and my throttle conroll was extrem sensitiv.
So now i have gas curve and i think it works good.
Her some mnore pictures but no flying pictures availible.
regards Christian
I need 3 attempt.
regards Christian
