Hi all
I've just ordered the Jeti MGPS and Rcdroidbox DC/DS to have a play at GPS triangle racing.
What sort of Android device are are you using for the Bluetooth connection and display?
Phill
Which android device for Rcdroidbox?
Re: Which android device for Rcdroidbox?
Phill
Samsung Galaxy Tab Pro is what I use. The big screen is a real help but whatever you choose make sure it is readable in BRIGHT sunlight or it will be useless for GPS flying.
Thanks John,
Do you have it attached to your tx?
Phill
Phill
Phill
Too big to fit on the TX so I have it on a stand up at eye level so I can glance at it easily if I need too. Properly set up there is very little need to look at the screen but it does help on occasions.
You will be able to see mine and others set up's on the 23rd.
