46% Pawnee rework in progress
rossco
Post by rossco » 17 Jun 2015, 02:05
A couple of years back I was looking for a quick fix to requiring a big tow plane fir my half scale asw 22. Enter the Bill Hemple Pawnee..at 198".
Having had many a chat with the designer I was assured my 222 would be just the ticket.... 3 months later the pawnee was flying but only with just enough power to fly the model..... it would seem parasitic drag was playing a monstrous affect on the models performance. A bigger motor would be needed. Now having decided I know where I want this one to go the 3w 275 wasn't going to cut the mustard so I've gone all out fitted the 3W 342 TS. Basically the biggest twin I can shoehorn into the cowl. So with Bill now freaking out about the airframe I bit the bullet and stripped the lot having decided that Bill was rote and that the airframe just wasn't going to survive 55% more horsepower so back to old school with 9.5mm square balsa coming too the rescue to back up the lightweight light ply structure..... things are now 100% stiffer!! So next up glass the turtle decks and bottom of the fuse for longevity and then add glass skins before fabric and paint.
rossco
Re: 46% Pawnee rework in progress
Post by rossco » 27 Jun 2015, 20:10
Pawnee rudder covered and pink tapes applied. That's another job to strike off the list
rossco
Post by rossco » 03 Aug 2015, 02:13
More work .... I've now sheeted the sides in fubreglass skin and hand laid glass over the upper decks fir better stability and longevity of the model.
Post by Barry_Cole » 03 Aug 2015, 16:11
You will need all that extra power, to haul all the extra weight.
What next, a supercharger...
Keep up the good work, Rossco.
GordonT
Post by GordonT » 06 Aug 2015, 15:53
While you're at it, why not scale it up to 100% - engines are easy to come by at that scale! :lol:
Mick Forey
Post by Mick Forey » 06 Aug 2015, 17:37
So are pilots.
ASW28, DG300, Penrose Pegasus, Reiher II
john greenfield
Post by john greenfield » 07 Aug 2015, 07:35
ARTF = Almost ready to finish ? Not exactly ready to fly !?
rossco
Post by rossco » 17 Aug 2015, 22:43
This one was most definitely ready to re engineer!
speaking of which..... the new undercarriage to replace the original rubbish.... now made from aircraft grade chrome olly tubing and tig welded together. ....mucb stronger now!!
rossco
Post by rossco » 29 Sep 2015, 07:00
things are moving slowly at the moment.... mainly due to a back injury and plane laziness. so over the weekend with some help from mate we cleaned out the workshop fir some room to move. . Last night I started getting ready to.mount the servo plugs to the fuselage filing out a slot to accept the plugs.
rossco
Post by rossco » 07 Oct 2015, 21:49
Finally fitted the ignition modules to the Pawnee the other day, this is how things are fitting up.
