30% Wilga Build
Elliot Howells
Re: 30% Wilga Build
Post by Elliot Howells »
I've been trying to make the milling vice work on my lathe to try and do this sort of thing, not having much success...
Getting the bottom of the legs at the correct angle needs a more muscular setup I'm sure, perhaps even an actual milling machine.
Have you seen Steve Davis' wilga? Pure craftsmanship.
Ell.
john greenfield
Re: 30% Wilga Build
Post by john greenfield »
Hi Elliot
I made the bottoms of the undercarriage legs for Darren's Wilga and yes they were made on a vertical milling machine after first turning the legs to size on a lathe. The trick is to make good jigs to hold the piece at the correct angles before machining.
Elliot Howells
Re: 30% Wilga Build
Thanks John,
maybe I'll outsource mine then, don't have room for a milling machine sadly, or a mate who owns one!
Thanks, Ell.
john greenfield
Re: 30% Wilga Build
Elliot Howells wrote:Thanks John,
Thanks, Ell.
Elliot
you should always have room for a mate who owns a milling machine !!!
zordak
Re: 30% Wilga Build
Post by zordak »
Have started building Bondies 30% Wilga and was wondering if anyone one this forum has a source for the bubbled clear doors and maybe premade cockpit install. Panel and seats!!
Regards Glenn from Australia.
