Flair K8 electrification
Fans and Thermals.
Andrew Matthews
Post by Andrew Matthews » 20 Nov 2017, 17:28
Hi All, I am currently building a Flair K8 and plan to modify it with the addition of a brushless motor.
I am looking for assistance with the power train as not sure exactly what motor / speed controller would be suitable.
I have been looking at either the Prop drive 4258 500kv or the sk3 4250 350kv motors and ESC of 80 -100 amps all being available via Hobby King.
Battery would need to be around a 5s
Is it possible to obtain commercial motor shaft extensions as I think this may also be a requirement of the build?
The all up weight of the model is planned to be around the 10 - 11 lb mark which should still enable hand launches from the slope or flat field, addition of the power train hopefully will eliminate the addition of the obligatory church roof.....
I would appreciate any suggestions
many thanks in advance
Andy
MarkDev
Re: Flair K8 electrification
Post by MarkDev » 20 Nov 2017, 19:48
Have a look at www.topmodel.fr the extended shafts are standard on some X Power motors, I used one with success.
M
Post by chris williams » 20 Nov 2017, 21:01
Also, Phoenix Model Products have silver steel extension shafts... http://www.phoenixmp.com/
Phill Tadman
Post by Phill Tadman » 21 Nov 2017, 06:38
Andrew Matthews
Post by Andrew Matthews » 21 Nov 2017, 09:22
Thanks very much for all of your suggestions, I will check them all out.
On the motor front does anyone have any suggestions to what size would be suitable for this project.
many thanks
Andy
Scale Police
Post by Scale Police » 21 Nov 2017, 09:39
Tut tut!
Post by Barry_Cole » 21 Nov 2017, 09:52
Andrew,
I have e-mailed you.
anthonym
Post by anthonym » 17 Jan 2018, 10:47
Thank you for these suggestions. Do you know gear motors of Kelvingear?
Regards.
