best motor ?
Fans and Thermals.
mick a
best motor ?
Post by mick a » 01 Aug 2018, 20:10
hi again
ok i have the size i want , and whittled it down to a choice of two motors
either a thumper or x-motor
both around same price
the x motor has long shaft that seems to be only difference
has anyone used either of these
MarkDev
Re: best motor ?
Post by MarkDev » 02 Aug 2018, 09:54
Yes, I had a 50 size in my 1/3 k6, putting out 1554w, using a long shaft with front bearing, certainly did the job with 6S 5400mah packgiving 6-8 climbs depending on the conditions. Battery quality is a big factor in motor behaviour.
mick a
Re: best motor ?
Post by mick a » 02 Aug 2018, 10:45
thanks for the info
the motor i have is 2200 w s should be loads
