Meanwhile, I have applied 2 layers of lightweight glass cloth to the cowl cheeks, sanded smooth & then waxed prior to making a backup plaster mould before digging out the majority of the balsa from the resultant shells - just in case
Once I have cut a nose aperture on each, the cheeks will be epoxied to the cowl hatch & then the relevant part of the hatch sides cut away to allow cooling air to be directed into the motor/ESC.
The fuselage has also been glassed & given an initial dust with primer to see how much further work is required prior to painting.
