ASK 14
Fans and Thermals.
arthur
ASK 14
Post by arthur » 18 Jun 2015, 08:36
Hi
I would appreciate some advice regarding getting a plan of a 1/3 scale ASK 14.
I have seen the free plan but but not to sure if I the now how to scale it to a working drawing.
Dispite what it says on this site about a cnc kit being available it seems this is not the case ?
I wonder if there is a problem, model wise with this glider as none of the `big names `in glider building and plan drawing seem to have had a go at it.
I have seen a post on RC Universe from a guy trying to locate a plan for the ask 14 ,and although dated some time ago he had no response.
Any info or ideas on the subject would be appreciated.
Thanks
Arthur
Noël Rumers
Re: ASK 14
Post by Noël Rumers » 18 Jun 2015, 23:06
Arthur,
We posted the plan on the site.
The CNC kit is something else. I know that a few people are building or have build the K14.
This I know because of the piece that have been send around the globe.
Building is one thing, finishing and flying it, is the ultimate thing!
This is one on film I know finished it and flew it see the film:
https://www.youtube.com/watch?v=nlVRIND ... e=youtu.be
The construction however is not that simple.
You should have a bit of building experience!!!
Maybe that is why it is not that popular.
I have have changed e.g. the wing joiner, you should use a round shaft. The screws to hold the wings are only working up front at the LE.
I solved the problem beginning this year to hold my wings to the fuselage by cutting a hole in the box behind the the flat steel joiner. A plastic tie rap or strap as we call it, will be pulled through the eye bolds so the wing can't move. After flying the strap is cut.
The drawing can be printed as it is.
You would have a 1/1 scaled drawing being 1/3 scale or the 1/4 scaled one.
A copy centre can do this for you.
If that fails I can send you the drawings over, PM me.
On the landing gear...
This is the hard part.
Please contact me for it if you want to go scaled like the drawings show you.
I made a few changes so it is more stable now. How would I know...
Mine is now flying very well and I have the same motor setup as the one in the film.
The motor however is no longer available from Graupner.
It was the Compact 610 Z with 29.6 V turning a 17x9" prop that is all feathering.
Works great but I told you this before...
I could also make you a CD with all the pictures about the K14 I have.
These will help you with your building 200%... ;)
See also the old forum on the K14...
I do hope this helps,
Noël
Re: ASK 14
Post by Cliff Evans » 19 Jun 2015, 00:19
Arther, I can print the plan for you, I can also laser cut the fuss formers, If Noel has a set of ribs in cad, I can cut them also. I have never been asked to do a short kit, but it would not be a problem to do so. Please feel free to contact me.
Noël Rumers
Re: ASK 14
Post by Noël Rumers » 20 Jun 2015, 13:24
Hi,
I can ask, my friend who designed the K14, if he has the wing designed in Compufoil.
If not I can do the wing too but at the end of July...holiday and more work first...a Milan...
Know the wing to the elevator should be only 2° or a bit less. This could be a bit to much on the drawing I was told.
I fly the fuselage originally build with a bit down elevator.
This morning I measured the settings as I fly the K14:
2° incidence to the elevator. The elevator is an all moving one.
Wash out is also on the tip 2° down so at zero at the wing tip.
The airfoil is the Wortmann FX 60-130 to 60-126.
Is the same airfoil as on Cliff Charlesworth K16.
Soars fantastic!!!
Ailerons are 15 mm up and 10 mm down
elevator is 25 mm up and down
rudder has max travel due to a swivel tail wheel or about 80 mm either side
airbrakes go 25° and 65° up on a 3 position switch on the stick.
I hope this helps,
Noël
Noël Rumers
Re: ASK 14
Post by Noël Rumers » 20 Jun 2015, 13:29
...on the wing joiner, took also pictures of this this morning.
Noël
The nut where the eye bolt is screwed into
arthur
Re: ASK 14
Post by arthur » 20 Jun 2015, 20:22
Thank you all for the advice, and information.
Reguards
Arthur
Hobby Jackson
Re: ASK 14
Post by Hobby Jackson » 16 Oct 2015, 21:43
Hello,
I am a prospective buyer of an ask 14 kit, I was given the link to one website that offers the kit and I would just like to know how hard it is to build.
This would be my first build so it would be cool to have assistance from you, the pictures I saw on the page were pretty cool, and looked helpful. I also found another website offering a kit and I will post both links below. Which one of the two kits would be best for a first time builder? I'm almost dead set on an ask 14 even though I heard it's not the best for a first time builder, It's a sexy ship and It fits in the light sport catergory here in the united states so I would be able to fly it when I finish training for my light sport license.
http://www.scalesailplanekits.com/#!/Po ... ort=normal
This is the website that was sent to me on this forum.
http://www.vogelsang-aeroscale.com/schneiderask14.html
This is the one that I found.
Thanks,
Hobby
Noël Rumers
Re: ASK 14
Post by Noël Rumers » 16 Oct 2015, 22:20
Hi Hobby,
I still think as you want to build the K14 as a first build, this is not the best idea you can come up with.
The wing building would be straight forward but with the under camber...
The fuselage is all covered with ply 0.4 mm or 0.6 mm. There is nothing straight on the fuselage either, so you would need some good experience with building a kind of ship like this, my thinking.
Although, there were a wish is, is always a way!!!
The landing gear is also on the drawings scaled.
I had to change quite a few things to make it bullet proof.
Over the last few days I had to reinforce the rear former of the gear.
Maybe a glider retract can be used instead...
The first K14 wood pack is our free download plan on this site. see motor gliders
I can help you with the cowl and canopy see the PM.
The other one is a bit bigger and this would help to work inside the fuselage.
Also the wing profile is better in the way that it can be flown slower during landing.
The Worthman FX 26-130 to 126 drops out the sky, if flown to slow, specially during landing, how do I know.
What you need to change too is the wing joiner.
Make it a round 16 mm steel, a linear bearing steel rod or glass fiber one of 20 mm dia.
Hope this helps,
Noël
Hobby Jackson
Re: ASK 14
Post by Hobby Jackson » 17 Oct 2015, 03:19
Hello,
well if you say the ask 14 would be a bad first build do you know of a motor glider that would be a good first build?
Also what kind of a controller and all of that associated equipment would be best for a first time model flier?
thanks,
Hobby
Re: ASK 14
Post by chris williams » 17 Oct 2015, 13:33
You might do worse than to try the 1/4 scale version of the K11. Relatively simple construction (no retract to worry about), handily-sized, inexpensive electronics and safe handling in the air, with a reasonable thermalling performance.
Details here:
http://www.scalesoaring.co.uk/VINTAGE/P ... Index.html
Video here
