Rebirth of the Tandem falke
Fans and Thermals.
stephen spittle
Post by stephen spittle »
This is the start of the repair on my Tandem faulk that got damaged at Chedder this year, when the power switch stopped working.
Would like to thank at the beginning of the rebuild. Cliff for cutting me the formers I required and Ian for the drawings.
john greenfield
Re: Rebirth of the Tandem falke
Post by john greenfield »
No doubt you will be round soon then if you have started the rebuild !!!?
Falke, Maybe??????????????????
stephen spittle
More work done on the Tandum today thanks to cliff for his formers that he supplied and making good use of the jig that I made a couple of years ago, it took all morning to set the jig up but then it was a walk in the park.
Noël Rumers
Post by Noël Rumers »
Professional work on hand here!!!
See how this K14 was repaired, the same way with a jig.
Keep up the nice work and next year another motor glider will soar the sky again.
Noël
stephen spittle
Very nice.
stephen spittle
Can anyone help me what does the Faulk look like in side the cockpit any pics would be very helpful.
ian davis
Post by ian davis »
Hi Stephen
Here's one shot to help you along.
Ian
ian davis
Post by ian davis »
Here;s another. Just looked at my TF. The main longeron should be straight not curved as in your pic.
Ian
stephen spittle
Here is a update, after a mess made on the first attempt with fitting the formers this was found with a trip to AEB.
So it all came off , and I started again.
This is why Ian your comment was correct the positioning of the formers coursed the stingers to curve, but these pictures show the stringers straight, as the second attempt is better now I was shown the error of my ways.
