Rebirth of the Tandem falke
Fans and Thermals.
stephen spittle
Re: Rebirth of the Tandem falke
Post by stephen spittle »
Today the covering was done with solatex
stephen spittle
Now to start the better of the two wings
john greenfield
Post by john greenfield »
Nice job on the fuz. As you have now started on the wings I guess I will see you in my workshop soon then !!!?
stephen spittle
You have that correct, it's funny I get a great feeling hacking I to a damaged Wiin to revel a good Skelton to work with.
A while ago I would only remove as small as possible the damage.
Thanks for that
stephen spittle
Front ribs have now been photo copied and draw on the balsa at work just now so they will be fitted tonight.
stephen spittle
Last night cutting back the damage
stephen spittle
Now to put the wing back together
stephen spittle
Skin is now back on the bottom side of the wing after a few hours from starting the repair.
john greenfield
Hi Stephen
Great rebuild but any chance of using a spell checker on your posts !!! I bet BC is cringing !?
"you have that correct, it's funny I get a great feeling hacking I to a damaged Wiin to revel a good Skelton to work with.
Thanks for that"
stephen spittle
Tail and fin covered and the first wing repaired ready for covering
