SFS 31 Milan
Fans and Thermals.
Noël Rumers
Re: SFS 31 Milan
Post by Noël Rumers »
...more pictures how...
Springs work fine
Springs work fine
1 mm hole
1 mm hole
2 mm hook
2 mm hook
fake spring on wire
fake spring on wire
Wire fixed with screw
Noël Rumers
Re: SFS 31 Milan
...With the doors open I installed an extra gliding stick at the mid door closing.
This hold the doors open like it should, scale view...
Noël
The door on the real Milan
Noël Rumers
Re: SFS 31 Milan
...had a problem with the post above with double pictures...Sorry...
Noël
Noël Rumers
Re: SFS 31 Milan
Hi,
the servos are in place now too.
All electrical work is finished also as there is:
the ignition connection, the ignition switch, the landing gear switch, the receiver switch and led controls and the onboard starter switch.
All connections are also soldered and secured. I like the switches on the instrument panel so that is nice but work also.
Before all goes in the fuselage, this needs now the final hand and then all can be painted where it should.
See the result,
Noël
Noël Rumers
Re: SFS 31 Milan
...and to secure the soldered leads, I did buy last year this little alu block.
The Green connectors fit in nicely.
The leads fit also, screw the two halves together and with the hot melt gun you just fill the chamber.
After cooling down, not long, you can open up the blocks and take the nicely covered and sealed connecter out.
This way you also have a much better grip to disconnect the M and F parts.
I also did buy a special stripping pliers, that fits all sorts of wires. Perfect too and no copper leads cut at all.
Both items helped me a lot solving the electricity arrangement in the model.
Noël
john greenfield
Re: SFS 31 Milan
Post by john greenfield »
I use the same aluminium tool to mould the ends onto MPX connectors. Very simple to use and available in the UK from Bernie at esoaringgadgets.
Highly recommended for anyone who uses MPX plugs and sockets.
Noël Rumers
Re: SFS 31 Milan
Hi John,
Indeed it works very well!!!
I managed to finish the canopy on my fuselage...
It fits nicely now with all in place.
See the pictures,
Noël
Noël Rumers
Re: SFS 31 Milan
The locking system...
Noël Rumers
Re: SFS 31 Milan
The aligning pin and hinges...
Noël Rumers
Re: SFS 31 Milan
...and the Vivak has been put on the frame with canopy glue, and after cutting the edge, hinges, a nice fit!
Now the window must be made and the rails.
Noël
