Electricityfied...!
Fans and Thermals.
Electricityfied...!
Motley's started the electrification of the 40% K8 Line. So far the budget has doubled and it's two years late... No, wait, that's the South West Line. :D :D :D This is Mott's 'spare' Phoenix K8, the big one: the motor has been shoehorned in with the help of some Smallpiece type engineering. There's a tow release buried in there too...
FrankS
Re: Electricityfied...!
Post by FrankS »
Did he not trust you to chuck it off the hill :D
MarkDev
Post by MarkDev »
Should we mere mortals concern ourselves with the finance rituals of an aero modelling project of such importance? :lol:
Can't quite see the motor details in the picture. Where did the prop yoke come from?
M
Gliders...
geoff_crew
Post by geoff_crew »
Oh i trust him Frank,but have you seen the rates he charges? :D Anyway it's only experimental : I.e. "a little experience and perhaps a tad mental" :lol:
Geoff :D
aka Motley
Euan Galloway
Post by Euan Galloway »
Geoff,
Good idea sticking it in the nose :D I have one of the G160 motors on 8s with a 20x8 wooden prop that gives 2000 watts at 69 amps and will fly your K8 , are you using 10s ?
cheers Euan.
terry white
Post by terry white »
;) Hope he allows for motor cooling air! Ter
geoff_crew
Euan, Just done a bench test using 10s with 18.5x10 folding prop (way too much power) & nearly dragged me off my feet, so still experimenting. :)
Terry, yes I've made provision for cooling, that's what those 2 holes are for each side of the motor shaft exit. There should also be some additional air flow via the tow release situated further down. However, WIP as they say. :)
Geoff
aka Motley
Mick Forey
Post by Mick Forey »
You can also use a spinner with a cooling hole as this direct feed to the motor: http://www.4-max.co.uk/folding-props-spinners.htm
Mick
ASW28, DG300, Penrose Pegasus, Reiher II
FrankS
Post by FrankS »
terry white wrote:;) Hope he allows for motor cooling air! Ter
It'll have plenty of time for cooling while he thermals around for a couple of hours between motor runs :D
