HW-4 FLAMINGO 1/4 SCALE
Re: HW-4 FLAMINGO 1/4 SCALE
Post by chris williams » 08 Nov 2019, 10:04
Having filled in the spaces with balsa, the first applications of filler are commenced...
mick a
Post by mick a » 08 Nov 2019, 17:13
watching the build, could you set the incidence just using the wing roots .?
i was thinking of doing that with the minimoa instead of wrestling with the wings .
Post by chris williams » 09 Nov 2019, 11:44
Unfortunately Mick, the wing roots don't really give you enough to work with, considering the importance of the task...
A final skim of filler with the wings on will ensure a near perfect fit. Obviously, it's important to run a blade through the filler just at that stage when it not too hard to cut, but not too soft to tear... (Dependant on ambient temperature & the amount of hardener added)
mick a
Post by mick a » 09 Nov 2019, 13:20
thanks chris
you make it look so easy
Trevor
Post by Trevor » 09 Nov 2019, 13:22
I’m in awe at your prowess with the filler Chris! Access to those servos looks a little awkward though?
Post by chris williams » 09 Nov 2019, 17:03
Not really, Trev, the big hole in the former gives reasonable access...
Meanwhile, the Flamingo's sister project, Motley's 1/4 scale Petrel, is just about mission capable... Fuselage Solartexed & painted, flying surfaces covered with film...
Post by VinceC » 09 Nov 2019, 17:58
That is absolutely disgraceful. After all the research I did to get the exact profile, which Chris used to create the plan, why bother building it when it turns out looking like an ice cream wrapper
Post by Cliff Evans » 09 Nov 2019, 18:00
What flavour is that?
Post by VinceC » 09 Nov 2019, 18:29
Vanilla with Blueberry sprinkles
