Simon WS
Post by Simon WS »
Thanks Roo. Rather a grey day!
Congratulations Paul - one down two to go (as it were!)
Si
Simon WS
Post by Simon WS »
Another small step towards completion...
Taped and glued some sides made from balsa to the binnacle so that the instrument panel itself would be recessed in the final part.
Then a quick strip of glass around them to form a support prior to adding the rest of the glass.
Then and bit of filling and painting.
I'm not even attempting an "Antonia Level" of scale detail, but having said that, I might make some pedals so that the pilot has somewhere to put his feet...
Simon
terry white
Post by terry white »
Beautiful work again Simon, not far off now. Ter.
Antonia
Post by Antonia »
Aww... go on Simon, you know you want too!..... :lol: :lol:
Brilliant work though, really looking forward to see your 800 in the flesh.
Simon WS
Post by Simon WS »
Antonia wrote:
01 Sep 2018, 22:32
Are you coming to a slope then Antonia? (just to wind Barry up!)
Thanks all...
Si
Simon WS
Post by Simon WS »
I've been severely lacking in motivation, but despite that I have actually been working hard on filling, sanding, filling, sanding, filling.....(you get the picture!). I didn't actually add up all the hours but I would guess it might be as many as 20 - and I'm still not really satisfied with it, but the fuselage is "done"
I also added the rudder pivot bar which I will (one day) add the rudder pedals to - almost certainly not before it's made it's first flight because right now I just want to get it into the air. Having said that, the one wing with non cured paint is pretty bad now so I think my pride won't allow me to let it be seen in public so I may re-do that before the maiden...
List of things to do:-
1. Re-do one wing
2. Add rudder pull pull control system
3. Paint wing servo covers
4. Mask & paint canopy outline
5. Calculate and add about 10Kg of nose weight (well, slight exaggeration, but it's going to be a lot!)
6. Sit down in a darkened room and decide if I wanna fly it!
Simon
Looks very nice Simon.
I’m sure we all want to see it take to the air :D
Simon WS
Post by Simon WS »
Thanks Peter. Fuselage cured enough to handle so tried a quick wing fit...
terry white
Nice very nice ;)
Simon WS
Post by Simon WS »
One of those jobs I don't like much - masking up and spraying the canopy outline. I discovered I had some Sikkens Plastoflex paint which is specially made for priming plastics (car bumpers mainly) so used that prior to top coat.
Looks so much nicer now...
Paul very kindly made me some servo covers, so I primed and painted those too and then fitted them today.
Finally with gritted teeth I sanded most of the non cured paint off the top of the wing with the problem and sprayed several new layers of 2K primer. I hope it has worked but it remains to be seen if the composite finish will be durable. Still it should look better than the pock marked surface did when I spray a new top coat on it tomorrow.
Getting there...
Si
