Baudis Antares 20E
Phill Tadman
Re: Baudis Antares 20E
Post by Phill Tadman »
Assembly for C of G
Phill
Phill Tadman
Electronics fitted. From top to bottom:
- Space for Jeti MGPS
- Jeti REX2 satellite receiver
- Dual Jeti 5800 Power Ion batteries
- Jeti MVARIO vario and expander for MGPS and MSPEED telemetry sensors
- Jeti Central Box 200
- Powerbox iGyro 3e
Left hand side has Florian Schambeck 150Ncm protection units for tow release and gear servos and a Jeti Single Bec for brake servo protection.
Not in picture on the left hand side is a Powerbox GPS that provides a speed correction factor for the iGyro.
I thought I'd try the iGyro to help with aerotow and solo slope launches. I've had a few close calls solo launching my ASW20 at the slope when wind gusts tilt the wings before I can get my fingers on the controls. The iGyro has gains for each control axis but I'll probably only use roll and yaw correction.
The iGyro only has the signal leads connected to preserve the Jeti Central box servo shorting function. The iGyro gets its power from the Gain and the spare Elevator 2 (backup) inputs.
Phill
Phill Tadman
Drilled and tapped ballast bars for an angle fitting which attaches to a blind nut behing the fuselage frame.
Phill
terry white
Post by terry white »
Hi Phil, Superb installation. Don't fly it, hang it on your lounge wall as an example of modern art. :D Ter.
Phill Tadman
terry white wrote:Hi Phil, Superb installation. Don't fly it, hang it on your lounge wall as an example of modern art. :D Ter.
Haha!
Not sure it would fit. It certainly fills the lounge.
Phill
A very nice model indeed
Phill Tadman
All finished!
Hoping to do the maiden soon!
Phill
ARUP
Post by ARUP »
That is a beautiful model!
Well done Phil . when are you planning to maidan?
Phill Tadman
Hi Roo,
It might be this Sunday - waiting for confirmation from AEB.
Otherwise it could be Middle Wallop in April.
Phill
