SZD - 36 Cobra 15 1:3 scale
skyhawk92
Post by skyhawk92 »
On the whole surface I applied a mix of epoxy and microballoons, to fill all the small gaps.
Immediately I placed 80g fiberglass and again saturate it with epoxy, then removed the excess of epoxy with small plastic plate.
skyhawk92
Post by skyhawk92 »
I removed ribs from the first half and reused them on the second half.
skyhawk92
Post by skyhawk92 »
I sticked together both halves, to see how they fit together, and started making some ribs for wings. :)
skyhawk92
Post by skyhawk92 »
Two halves sanded on the inside and 80g fiberglass cut in shapes. One layer over all fuselage and another just on the front part.
skyhawk92
Post by skyhawk92 »
Same as on the outside, I first fill the gaps with microballoon and then saturate fiberglass with epoxy.
skyhawk92
Post by skyhawk92 »
Both halves aligned on edge and sticked together.
skyhawk92
Post by skyhawk92 »
On the outside, stiched together only with a single strip of glass fibers.
skyhawk92
Post by skyhawk92 »
Main wing support done and shaped.
skyhawk92
Post by skyhawk92 »
Square tube with holes for screws, which will be inside fuselage, made out of GFK plate.
skyhawk92
Post by skyhawk92 »
Square tube, covered with few layers of carbon fiber strings and filled with a mix of epoxy and cotton fibers around nuts.
