SZD - 36 Cobra 15 1:3 scale
Tom Pack
Post by Tom Pack »
Martynk wrote:
06 Mar 2018, 09:11
What is the box for that is attached to the rudder?
Superb craftsmanship by the way.
Elevator servo.....
Martynk
Post by Martynk »
Thanks Tom..
skyhawk92
Post by skyhawk92 »
Correct yes, it's for elevator servo.
Roughly filled the gap with microballoon around the main wing support.
skyhawk92
Post by skyhawk92 »
I attached rudder handle to the bottom part of rudder, so bottom part is easier to make.
skyhawk92
Post by skyhawk92 »
I filled the remaining space with pieces of styrodur and glued them together with polyurethane glue.
skyhawk92
Post by skyhawk92 »
Sanded all together.
skyhawk92
Post by skyhawk92 »
Covered the whole surface with 25g glass fiber and 2 extra layers on styrodur part to make it tougher.
skyhawk92
Post by skyhawk92 »
Same on the other side.
skyhawk92
Post by skyhawk92 »
Because rudder is quite massive, edges are a bit thicker.
skyhawk92
Post by skyhawk92 »
At the end of the stick I put glass fiber and soaked it with epoxy, leveled it up with lathe and made thread so it can be pulled out using screw.
