Page 12 of 14
Posted: 07 Mar 2018, 01:59
by Tom Pack
Martynk wrote:
06 Mar 2018, 09:11
What is the box for that is attached to the rudder?
Superb craftsmanship by the way.
Elevator servo.....
Posted: 07 Mar 2018, 07:58
by Martynk
Thanks Tom..
Posted: 12 Mar 2018, 06:29
by skyhawk92
Correct yes, it's for elevator servo.
Roughly filled the gap with microballoon around the main wing support.
Posted: 26 Mar 2018, 07:15
by skyhawk92
I attached rudder handle to the bottom part of rudder, so bottom part is easier to make.
by skyhawk92
I filled the remaining space with pieces of styrodur and glued them together with polyurethane glue.
Posted: 05 Apr 2018, 06:22
by skyhawk92
Sanded all together.
Posted: 05 Apr 2018, 06:23
by skyhawk92
Covered the whole surface with 25g glass fiber and 2 extra layers on styrodur part to make it tougher.
Posted: 10 Apr 2018, 08:40
by skyhawk92
Same on the other side.
Posted: 10 Apr 2018, 08:41
by skyhawk92
Because rudder is quite massive, edges are a bit thicker.
Posted: 25 Apr 2018, 06:29
by skyhawk92
At the end of the stick I put glass fiber and soaked it with epoxy, leveled it up with lathe and made thread so it can be pulled out using screw.
