SZD - 36 Cobra 15 1:3 scale
skyhawk92
Post by skyhawk92 »
That's it so far, both threads are equalized :) I will post on both from now on.
Chris Jesshope
Post by Chris Jesshope »
Skyhawk,
I have just been catching up with your thread. This technique is very interesting. You might like to know that it is also used in the construction of sailing yacht hulls, although I have typically seen cedar strip rather than balsa used and there and usually two or three layers laid up in different directions but that is used in a 10m structure that is going to hold 1 ton of keel! It results in a very light and strong structure.
keep up the good work!
Chris
skyhawk92
Post by skyhawk92 »
Chris Jesshope wrote:Skyhawk,
Chris
Exactly :) that's where I got inspiration.
skyhawk92
Post by skyhawk92 »
Main thing about the wing construction are bottom shapes of the ribs. This type of construction is fast and accurate and allows to build each control surface separately.
Bottom part shapes of the ribs(jigs or how should I call them... ) are made of 3mm plywood and on top they are covered with tape to prevent anything to stick on them later. To hold them in place, I use pieces of aluminium profiles with M3 size screws. All holes must be on same level(in height).
skyhawk92
Post by skyhawk92 »
I build first 5 ribs of the left and right half of the wing and insert the main supporter and set the V angle.
Jigs set in place. Same are used for both halves, no need to use doubles.
skyhawk92
Post by skyhawk92 »
Putting ribs in place. First 5 of them are made of plywood.
skyhawk92
Post by skyhawk92 »
Two plywood plates are glued in place where the supporter will be.
skyhawk92
Post by skyhawk92 »
Rear part of the ribs glued.
skyhawk92
Post by skyhawk92 »
Second part of the middle wing section and wing supporters glued.
skyhawk92
Post by skyhawk92 »
Rest of the wing being built.
