SZD - 36 Cobra 15 1:3 scale
On the bottom part of the wing I cut holes for the brakes. Opening for servo is a bit larger here for easier access, because I will insert brakes at the very end.
- VinceC
- Site Admin
Time for a Cat Flap in a glider
Same as on the first one, I made edge on which the cover will be tightened.
Around the cover, I taped double sided tape, which is only 0,5 - 1 mm thick, then I tightened cover in place.
When epoxy hardened, I removed cover and sanded the edge.
On the places, where the servos will be, I sticked in plywood.
Servo for airbrakes set in place, with L profile made from alluminium.
