Asw 27 4.3 build
Re: Asw 27 4.3 build
Servo holes cut out and wire channels cut with hot metal rod
Wing tips made today. About 1 hours work. Two pieces of ply lamented together with metal pins that slot in to carbon tubes in the wings. Need to be sanded.
Tail cut
A bit of a experiment tail glassed with carbon and then vac bagged using a vac packing bag that is used for storage for beding and clothing sucked out with vacuum cleaner
Out of bag and sanded plus elevator cut out. Now being filled.
terry white
Post by terry white »
Doing well Roo, was the vac bag and vacuum cleaner successful?
I have always use the Lay flat tubing ,supplied by the molding suppliers for vacuum bagging processes.Although it opens into a tube it comes on a roll flat until you slide your work piece into it, it is very smooth and leaves the work-piece the same, can be used for any length you wish. seal the ends with sellotape after loading your work to make it airtight. Can be used more than once.
I have lots of this material available to anyone who wishes to have a go at vac-bagging and would happily do a' how too' here on the forum if enough are interested.
Just send me a P.M. with your address and length of bag required and I will send you some in the post.
Keep up the good work Roo. Regards Terry
Would happily do a' how to' here on the forum if enough are interested.
Terry, that would be a good idea. With photos if possible.
john greenfield
Post by john greenfield »
Barry_Cole wrote:
14 Nov 2017, 12:41
Or even a video !
Richard_A
Post by Richard_A »
Dark art. We need enlightenment Terry. A video would be good.
Richard.
Terry, that would even be of interest to us woodies.
