1/4 Scale ASK21
Re: 1/4 Scale ASK21
Post by Peter Balcombe » 03 Jul 2020, 11:15
With all ribs in place, the joiner tube has now been epoxied in position and then fully boxed in with ply sheet & epoxy to make a solid lump tied to the spars.
The rear incidence tube has also been added & boxed in using hard balsa, faced with 1/16" ply.
Airbrake fitted & pushrod routed through to the servo bay.
Lastly, a 1/8" balsa doubler strip has been fitted around the wing taper break rib in preparation for skinning, which I have decided to do as separate Inboard & outboard sections.
The structure now just needs to be sanded over to get the False LE & TE to profile prior to applying the full width upper skins.
Re: 1/4 Scale ASK21
Post by Peter Balcombe » 05 Jul 2020, 11:24
Upper sheeting has been applied in 2 sections once rib doubler had been fitted at the taper break.
I now need to find the Brake blade outline in the upper sheeting - if I can find the piece of paper I wrote the measurements on ;)
Aileron servo cable threaded though & now awaits more cable to be able install the Brake servo cable.
Photos below show the current state, noting that a 1.5" TE strip will be fitted once the sheeting is complete.
(The front part of the ailerons is already included in the build so far, complete with angled aileron LE spar).
Re: 1/4 Scale ASK21
Post by Peter Balcombe » 10 Jul 2020, 10:01
Underside now sheeted & servo hatches opened up.
1.5” TE stock now being applied to the rear edge, starting with outer section - aligning upper surface to wing profile (excess lower surface to be removed later when profiled to wing section).
Re: 1/4 Scale ASK21
Post by Peter Balcombe » 10 Jul 2020, 18:44
With bottom spar tapered as required this morning, the 2nd wing structure is well on its way - with not a drop of Cyano in sight!
The Ply web sitting on the top of the wing is for the rear spars yet to be fitted. (The web fits from the underside anyway).
Re: 1/4 Scale ASK21
Post by Peter Balcombe » 18 Jul 2020, 12:35
With the top skin now on the 2nd wing & the lower building tabs removed, I couldn’t resist putting the joiner tube in the fuselage in order to try an initial assembly.
Tailplane also sat in position to get an impression of the overall size.
Still a lot of work to be done, but slowly getting there :)
Re: 1/4 Scale ASK21
Post by Cliff Evans » 18 Jul 2020, 14:20
Looking good Peter.
Re: 1/4 Scale ASK21
Post by roo Hawkins » 21 Jul 2020, 13:20
Nice mate
Re: 1/4 Scale ASK21
Post by Peter Balcombe » 30 Jul 2020, 15:00
With both wings now fully sheeted & fuselage joiner installation complete, attention moves to completing the wings.
After profiling the lower edge of the stock TE section to match the distinct undercamber in this TE area, the aileron has now been separated on the 1st wing.
(This involved remembering to mark the hinge line on the top surface - defined by rear edge of vertical hinge spar) prior to adding the lower skin). The aileron could then be cut off by inserting a scalpel blade through the top skin, down the rear of the hinge spar & out through the bottom skin at the ends & centre of the aileron. Join up the lower surface points & cut through skin & ribs using a razor saw. There is room for error at the bottom due to the gap formed by the angled aileron LE web.
Once removed the aileron LE bevel can be tidied up.
