1/4 Scale ASK21
Re: 1/4 Scale ASK21
Hi Brian,
It’s probably not necessarily the normal way to do it, but it’s my first time & I already have the canopy opening blanks saved from the fuselage mould making process ;)
Re: 1/4 Scale ASK21
I know that canopy plugs are normally made from a hardwood core, but I am going to have a go at something different - given my starting point with two perfectly profiled canopy opening blanks.
I plan to end up with solid herculite (or similar) plaster moulding plugs, but will be trying a different route to get there. It may not work, but if it does, then it should make life a lot easier than carving two large wooden plugs from scratch.
The extended canopy opening blanks have now been initially filled & shaped to conform to the canopy opening profiles. The pic below shows one of them before the front & rear release angles were increased. The resultant block will also be given more generous rounded corners to improve release tapers prior to sealing with glass & epoxy resin.
Re: 1/4 Scale ASK21
Back to the wings, which have now been glassed and also received a thin sealing coat of epoxy resin to leave a gloss finish.
Once rubbed back a bit with fine wet&dry used wet, the ailerons will be hinged & servo installation sorted prior to painting - which might now have to wait a bit!
Re: 1/4 Scale ASK21
Wings look lovely Peter. The camber on the undersurface looks very realistic.
Re: 1/4 Scale ASK21
Jolly Roger wrote:
15 Oct 2020, 22:53
After talking to Noël Rumers before the wings were designed several years ago, I decided to use the full size FX section as Noël reckoned that with a tip chord of >130mm, that would work & allow the model to fly at a scale speed.
We will see if that is so in due course ;)
Re: 1/4 Scale ASK21
All looking very good Peter, but where do the golf clubs fit into this equation?
Brian. :D
