Page 1 of 3
Re: Jilles Smits Bergfalke 11_55 built by Clive Learwood**
Posted: 09 Aug 2017, 10:01
by Martynk
This looks superb Cliff. What CAD systems are you using? Its very impressive
Posted: 09 Aug 2017, 10:36
by Martynk
Superb draughting skills - I am very impressed
Posted: 13 Aug 2017, 07:19
by Jilles
Assembly of laser cut items and stringers always goes pretty fast. Adding plankingand other details items slow things a bit.
But that is part of the building a large scale glider.
Result to date looks great make sure things are kept straight and level when adding tail bits and planking. An Obvious remark, but experience tells me you cannot be too critical on that issue
Posted: 13 Oct 2017, 05:02
by Martynk
That looks lovely and an amazingly tidy workspace as well
Posted: 29 Apr 2018, 09:50
by VinceC
This is going to make a nice model. Well done Clive
Posted: 03 Feb 2019, 00:02
by Philip Hickey
Hi Cliff, This is my Bergfalke i have built
Posted: 20 Feb 2019, 20:57
by Philip Hickey
Any Flight details on the model[img]
Posted: 02 Oct 2020, 16:19
Adam,
I suspect that in common with other ‘short’ laser cut woodie kits, the full Bergfalke kit comprises a plan & set of laser cut formers, ribs etc/other specifically shaped balsa/Liteply/Ply parts.
The builder needs to study the plan to work out what other standard balsa/ply/metal sheet & strip materials are needed to complete the build.
From my experience, any designer (certainly true in Jilles’ case) tends to identify standard wood sizes on the plan, which you can normally get from SLEC/Balsacabin etc. although you may need to splice standard lengths to get the overall length required for wing spar etc.
Posted: 02 Oct 2020, 17:52
Here you go Adam.
Bergfalke bom.pdf
(850.1 KiB) Downloaded 351 times
Posted: 02 Oct 2020, 23:30
But aren't models like that? Nothing that is not available from SlecUk!!!
