Jilles Smits Bergfalke 11_55 built by Clive Learwood
Re: Jilles Smits Bergfalke 11_55 built by Clive Learwood
Here you go Adam.
Bergfalke bom.pdf
(850.1 KiB) Downloaded 56 times
Laser Cut sailplanes
Adam C
Post by Adam C »
Clive,
Thanks. A real mixed bag of dimensions! I may have to give this a miss.
But aren't models like that? Nothing that is not available from SlecUk!!!
Adam, don’t be put off by mix of metric & imperial dimensions. Just use nearest imperial in U.K.
Thus, 0.8mm is 1/32”, 1.5mm is 1/16”, 2.4mm is 3/32”, 3mm is 1/8 etc.
I doubt that you will find it easier unless you buy an ARTF model.
Jilles
Post by Jilles »
My style of drawing comes from my industrial background. A project comes with a BOM short for Bill Of Materials. drawing shows part numbers or code. the BOM gives details/ Standard drawing practices. This gives an overview of material required in one place. Drawings would become difficult to read and clogged up with text and repeating info.
Building a vintage glider of some size is a project in itself and part of that side of the hobby. The alternative is an ARF.
Adam C
Post by Adam C »
Thanks all.
Well aware of the world of building. Everyone has their preferences and mine is to look for simplicity in terms of wood dimensions used. Just finished a 4m Komar with only 3 different spruce dimensions and all using 2mm sheet. Simples!
I'll give it another look but other bergfalkes are avsialbe that work for me.
Not very challenging then! Just as well go ARTF
Adam, you have to face the challenge head on, as that what modelling is, a challenge, not just an easy ride or else you would go to the Toy Shop. If you are concerned about the material sizes, just rip them from standard sheet sizes with a small table saw, problem solved.
Adam C
Post by Adam C »
Guys, getting a bit bored repeating this but Ive built over 100 scratch models so Im well aware of the challenges. I just prefer designs that reduce the need to source or cut masses of different dimension wood .
Good designs simplify not complicate a build. Why do you need 5 different stringer sizes for example ? Shame as its a lovely well though out design.
Thanks for the input , helpful or otherwise but I have found a nice laser cut czech bergfalke kit that suits my needs perfectly.
safe flying...
Over 100 !! Well is there any collateral damage or are they all still around
