FW Models 1:4.5 ASW17
Phill Tadman
Post by Phill Tadman »
Hi all
About to start my FW Models 1:4.5 ASW17which was supplied by Phil H.
It has a Migflight Jetec E80 already fitted.
https://www.fw-models.de/content/modelle/asw17145.php
A few pictures to start...
Phill
Phill Tadman
Re: FW Models 1:4.5 ASW17
And a few more...
Phill
Phill Tadman
Hoping to use these Servorahman LDS frames with KST X10 minis.
Test fit shows some missalignment causing the frame to flex.
Do you think this is significant?
[youtube][/youtube]
Phill
terry white
Post by terry white »
Hi Phil,
What a super model that is. You're one lucky guy. Anything these guys produce is just superb.
Please Keep this build thread going we're all eyes!
As for the servo's what is the Torque of each one?
How do you slide the bent(dihedral) carbon joiner through the fus?
What did you have to buy the wife to get it. ;)
Regards Terry
Phill Tadman
terry white wrote:
22 Oct 2017, 18:50
Hi Phil,
Regards Terry
Hi Terry,
Servo spec is 7.5kg/cm at 8.4V.
The joiner is quite a loose fit in the fuselage. It is all held snug with the incidence pins when wings fitted.
My wife is cool about this one, although I haven’t told her about the Baudis Skywalker I have on order :?
Phill
Phill Tadman
Ok, the KST X10 minis do not work with the servorahmen LDS frames.
The LDS small servo horns don't fit on the servo spline and the servo size is slghtly different to the KST 225MG and distort the frame.
I’ve found some KST X10 mini frames from emc-vega.de which I’ll try with the supplied control surface horns which are very low profile anyway.
Phill
Phill Tadman
Horns glued into pre cut slots.
I reduced the height of the outer aileron horns as the wing section is very thin at the outer aileron position
Phill Tadman
Servo frames epoxied in
Phill Tadman
Wing loom soldered to D sub
Phill Tadman
Wires insulated and the whole shrouded with hot glue in a winkler mould
