Page 4 of 5
Re: MU13 Charlesworth
Posted: 09 Nov 2018, 20:06
by John Vella
Thanks for the advice. I will replace with twisted triwire. No point taking a chance. Regards John.
Posted: 05 Dec 2018, 13:13
by John Vella
Next the making of the aileron. It is faced with 1.5mm medium balsa from 48 inch stock. The control horn is glass fibre mounted in a box of 1.5mm ply between the ribs. The aileron is fitted and top hinged on 5 "Robart" metal pinned hinges. The wing tip and tip aileron profiles were further blended. The 0.4mm ply facings were added top and bottom, and the 0.4mm cap strips which blend into TE gussets. This scale feature adds considerable strength to a fragile point of the wing. The balsa facings were worked to give a small gap at the top and V section underneath with room for the fitting of an aerodynamic seal. The spoiler box frame is built from 2.6mm sq spruce strip and 4mm section balsa rib doublers. The "letter box" 0.4mm ply surround is glued on. The leading edge will but upto the wing D box 0.4 ply sheeting. The Next job will be the ply root facing rib to fit and blend in with the fuselage. Some more reprofiling of the ribs then the fun of wing skinning begins. I will be using J G' s method (See Ghost Squadron excellent video). Regards John.
Posted: 08 Dec 2018, 10:03
by Chris Jesshope
Hi John, Robbie,
just a comment on the twisted pair issue. There is no crosstalk in a 3 wire flat cable as you only have one signal wire. By definition, to get crosstalk you need more than one signal. The two other wires are constant potential, ground and VDD and hence can not contribute any EM interference to the signal wire. The 3 wire cable may be better for longer runs as it tends to have a larger x-section than the flat and hence less resistance and smaller voltage drop, especially on powerful servos.
Keep up the good work John.
Chris
Posted: 08 Dec 2018, 10:44
Chris,
I understand that twisted wires are principally used to reduce Mutual interference from external radiated noise sources.
The idea is that the twisting ensures that all wires pick up the same amount of interference, rather than some being partially shielded from noise coming from any given direction.
The presence of similar noise on all wires means that the differential signal between the wires (which is usually what the device at the end of the wires is interested in) is largely unaffected by the interference picked up.
This type of wiring was often backed in particularly noisy environments with differential signal receivers which were able to virtually totally ignore any interference common to both signal & ground lines.
Note that twisted wires (for Mutual Interference reduction) & ferrite rings (for Conducted interference reduction) were common in 35MHz days when the long aileron etc. servo runs approached 1/4 wavelength, but this is no longer the case with 2.4GHz equipment as the wavelength is 1000 times shorter.
Modern equipment also tends to have for better out-of-band filtering performance.
Posted: 08 Dec 2018, 17:17
by John Vella
Hi Gents what you say makes perfect sense to me. Thanks and on the subject of interference I would be much more concerned about mobile phones on the flight line. I gather they have to be very close to the transmitter to have any affect, however I keep mine in the model park when flying and not on my person. Regards John.
Posted: 11 Dec 2018, 01:39
by Chris Jesshope
Peter, John,
There are two issues here, one is crosstalk, one interference due to external magnetic fields. There is, as I said, no crosstalk issue as we have power, ground and one signal wire in the cable.
External interference from magnetic fields is generally an issue in very long signal cables, e.g. telephone wires, where signals are attenuated significantly and hence become susceptable to noise. And yes in such cases differential signalling is used as well as twisted pair. However induced noise is unlikely to be any higher than a few mv and differential noise, i.e. the difference on two wires due to their position relative to the magnetic field, will be less.
Differential signalling detects the change between signals, +/- to -/+ so can be used to detect very weak signals propageted over long distances. Baseband as is used in servos detects a range, e.g. 4 to 5v as high and 0 to 1v as low. The frequency is too low for impedance missmatch to have a significant attenuation of signals therefore there is not going to be a problem. Yes 35MHz was worse as servo wires could make good aerials but even here You are talking belt and braces.
John, if phones are going to have any effect its goingto be throughthe receiver not the servo wires and at that only a statistical one as the signals are spread spectrum with unique codes to separate signal from noise.
Having said all that it certainly can not harm to use twisted cables.
Posted: 31 Dec 2018, 16:31
by John Vella
Here we go with some more progress over the last few weeks. The top sheeting of 0.4mm ply was glued on with 6mm balsa rib doublers at joints. All reprofiling of ribs etc were with slivers of balsa soaked in cyano for a durable sandable finish. PVA glue was used on skinning with the hot iron method. Around the tips Aliphatic (yellow) glue was used for feather sanding to profiles. Aliphatic glue was used on most of the structure including the rib caps. The Delux Materials Resin does have a fast grab time if used in 25 deg temperature of my model room. The photo of the root end of the Aileron shows the structure of the balsa facing on 5mm sq spruce boxed by 0.4 mm ply top and bottom. 0.4 mm ply cap strips flair into the TE of balsa 0.8mm ply balsa sandwich. 6mm thick ply blocks were glued to the root ribs to take screw hooks for rubber band wing retainers.The bottom sheeting was then added with rib caps and capping of the cutouts and covers for the spoiler and Aileron servos. The top skin is joined at rib 28 to accommodate the compound curve at the tip. The gentler curve underneath allows a continuous skin to the tip. So next year the balsa leading edge and root rib capping will complete the starboard wing. A HAPPY NEW YEAR to you all.
Posted: 31 Dec 2018, 16:39
Looking good John, have you a colour scheme in mind yet?
Posted: 01 Jan 2019, 09:54
by John Vella
Cliff, happy New Year. At this point I would like to add my thanks to you for all your hard work . I am struggling with an MU13 scheme . With my K8s you are spoilt for choice. Any suggestions for a MU13D scheme are welcome. Regards John.
Posted: 10 Jan 2019, 16:36
by John Vella
The next little job is fitting and shaping the leading edge. It is from 4ft long 6mm medium hard balsa. Aliphatic resin was used and pinned in place . The profiling started with the trusty David Plane then sanding with the butting sheet ply protected with insulating tape. The Gottingen 540 profile is pretty blunt and crude by modern day standards, but does the job and is scale. (Scale Police take note). Next the wing tips were profiled with the 0.4 mm ply blending into the balsa. The final constructional job was the root rib facings made from 1.6 birch ply, and made in 2 sections to account for the bend at the canopy cut out. On offering up the wing on its joiners the fit looked pretty good. The starboard wing including servos comes out at 38 ozs. On most of my gliders the wings weigh about half the gross weight of the complete model. So it looks like a target weight of around 10lbs might be achievable.
