scratch built 7m ASH 31
Hi, I started this about 6 weeks ago but it has been on hold. I am not planing to do one of my fast builds as I have a PT ASW 20 to do as well. I needed to start this so I can get over the fox build. I built a 5m ASH 31 about 3 years ago. It was OK but I wish I had made it in 1/3 scale. The fuz foam plug has been shaped but not filled and sanded plus the blue foam wing cores have been cut. I will post some more when more has been done.
- Simon WS
Re: scratch built 7m ASH 31
Looking good Roo!...
Si
Si
Started to do a bit more on this plus I have ordered the glass and epoxy .doing bits in between outher models .to many repairs and builds.
Why the blue foam for the wings Roo? Is it just the obvious thing that it is stronger than EPS??
It makes a more accurate cut plus it is stronger
- Simon WS
Finished next week then Roo?!
Simon
Simon
Plug is now filled with wilco wall filler.just now need to sand and it is really for glassing
