scratch built 7m ASH 31
Re: scratch built 7m ASH 31
Wing joiners set in this morning. 18mm steel and 20 mm carbon tube fixed in with epoxy and carbon mix this is to set it it the right place it well then be carbon and epoxy reinforced later.
Leading edge fixed on and carbon tape on top of spar done. Started the outer panels.
Outer wing joiner made up out of steel tube and glass reinforced with carbon.
Bottom veneer skin has been epoxied on and carbon T.E added.
