GenesisII
Re: GenesisII
Post by Cliff Evans » 22 Jan 2019, 09:10
Thanks!
Foxsoar
Re: GenesisII
Post by Foxsoar » 22 Jan 2019, 12:20
Hello All,
I have been flying a 1/3 Scale Genesis 2 for almost 20 years. Winch launch and mostly aero tow. I was able to get a set of plans before the full scale flew. My Dad built a G1 also before the full scale prototype flew and gave back good data to the full scale pilots. Interesting plane that flies pretty good. I used an airfoil Jim Marske teaked for our model reynolds numbers. Flies fine, but does not stay up as good as other 1/3 scale ships.
What do you want to know? 8-)
Mike Fox
Re: GenesisII
Post by Cliff Evans » 22 Jan 2019, 12:33
Just general setup really, and any vices it may have, no where near ready yet.
Foxsoar
Re: GenesisII
Post by Foxsoar » 22 Jan 2019, 19:58
Cliff,
Are you building from Marske plans? If so go by his drawings. Mine flew easily from the start. Mine weighs about 13 lbs. Sorry no translation. Dads G1 was about 11lbs. I made a mold for my fuse and the rest is bagged glass. See attached pic of my model.
CG on the drawings is right on to start with. I have moved it around. With a forward CG, like what is shown, it flies great, but does not hang or thermal the best. It thermals better with a rear CG, but tends to hunt in straight flight. I thought about using a gyro to help that out. Talking with Marske, he said some pilots are using a sliding seat to help with the same issue. My battery is up front and required very little nose weight. I have also thought about putting in a movable CG weight.
I have 2 retracts in mine. Placement of the main gear is important. The full size moved the wheel back maybe 4" to start with. I moved mine too, to copy. I also went to a smaller front wheel so the plane pitched negative on landing. With the short fuse, it will go positive and try to fly again and with no real airspeed, it does a dork landing. :x I have also found landing with full spoiler at touch down, seem to stay on the ground better. Dads G1 did not have retracts and when he landing....it landed 3-5 times before staying on the ground. He also did not have spoilers. It was mostly a concept model.
That's about it for quirks or odd handling. Being a wing, it looks a little different in the air and it flies with the nose down, because of no long tail back there.
If I were to build another. I would use the P3 airfoil. I think it looks more like a model airfoil. Mine also has too much reflex, it is stable, but for high speed pass it takes a lot of down elevator. Marske suggested cutting the bottom of the wing and pushing the trailing edge down some. Like with a lot of designs, there are always little things that might make it better.
Mike
Rich vale
Re: GenesisII
Post by Rich vale » 08 May 2019, 18:24
Basic spar and wing lay up
Spars in jig
left wing lay up
wing lay up 1
wing lay up 2
Re: GenesisII
Post by Cliff Evans » 08 May 2019, 18:38
Foxsoar wrote:
22 Jan 2019, 19:58
Cliff,
Mike
It is being built from the plan by Jilles Smits
Rich vale
Re: GenesisII
Post by Rich vale » 09 May 2019, 06:54
Elevator pushrod setup
Fin bones
push rod and belcranks
3d printed belcranks
Rich vale
Re: GenesisII
Post by Rich vale » 14 May 2019, 06:39
Fuselage parts assembled around double wing steel tubes.
Basic bones
Start of fuse woodwork
fuse and wing steel box
Rich vale
Re: GenesisII
Post by Rich vale » 25 May 2019, 17:04
Good progress so far
Fin assembly attached
canopy fillets and nose retract
General layout
rear retract
front retract
Ready to sheet
Rich vale
Re: GenesisII
Post by Rich vale » 22 Jun 2019, 12:10
Sheeting finished on fuselage apart from filling and glassing. Wings first fit to fuselage. Next to flair wings to fuselage ready for glassing.
ready for filling at root joint
It is bigger than it looks in sections
wing fillets to be faired in
All steels and rear pegs line up well
