Page 2 of 4
Re: GenesisII
Posted: 11 Jan 2019, 18:51
Well done John :D :D
Re: GenesisII
Posted: 15 Jan 2019, 07:28
Just like buses 😆😆
Re: GenesisII
Posted: 15 Jan 2019, 07:43
by roo Hawkins
Very nice
Re: GenesisII
Posted: 15 Jan 2019, 09:20
Peter Balcombe wrote:
15 Jan 2019, 07:28
Just like buses 😆😆
Well, someone had to say it.....
8-) 8-)
Re: GenesisII
Posted: 15 Jan 2019, 10:47
Not in my neck of the woods they don't!
Brian. ;)
Re: GenesisII
Posted: 17 Jan 2019, 00:29
by ARUP
You might contact Mike Fox in the USA about this sailplane. He is an expert with it in model form. I am going to state that there are probably no better RC sailplane pilots than he! I have personally witnessed some of his amazing flying feats with this bird. I am sure he had to relocate the wheels due to some odd touch down porpoising problem. It is also my understanding that Mike was able to give the full scale test pilot some information about odd spinning and other flight characteristics that were spot on for the model was pretty much a proof-of-concept device before the full scale one was built(?)
Re: GenesisII
Posted: 22 Jan 2019, 01:30
by ARUP
Cliff Evans wrote:
17 Jan 2019, 08:28
Arup, please put him in touch!
Mike has gotten the mssg(?) through a mutual friend so I hope he contacts you soon. The mutual friend kept talking about a German site and I kept correcting him stating it is the English, United Kingdom, site! If no news forthcoming I will try again.
Re: GenesisII
Posted: 22 Jan 2019, 12:20
by Foxsoar
Hello All,
I have been flying a 1/3 Scale Genesis 2 for almost 20 years. Winch launch and mostly aero tow. I was able to get a set of plans before the full scale flew. My Dad built a G1 also before the full scale prototype flew and gave back good data to the full scale pilots. Interesting plane that flies pretty good. I used an airfoil Jim Marske teaked for our model reynolds numbers. Flies fine, but does not stay up as good as other 1/3 scale ships.
What do you want to know? 8-)
Mike Fox
Re: GenesisII
Posted: 22 Jan 2019, 19:58
by Foxsoar
Cliff,
Are you building from Marske plans? If so go by his drawings. Mine flew easily from the start. Mine weighs about 13 lbs. Sorry no translation. Dads G1 was about 11lbs. I made a mold for my fuse and the rest is bagged glass. See attached pic of my model.
CG on the drawings is right on to start with. I have moved it around. With a forward CG, like what is shown, it flies great, but does not hang or thermal the best. It thermals better with a rear CG, but tends to hunt in straight flight. I thought about using a gyro to help that out. Talking with Marske, he said some pilots are using a sliding seat to help with the same issue. My battery is up front and required very little nose weight. I have also thought about putting in a movable CG weight.
I have 2 retracts in mine. Placement of the main gear is important. The full size moved the wheel back maybe 4" to start with. I moved mine too, to copy. I also went to a smaller front wheel so the plane pitched negative on landing. With the short fuse, it will go positive and try to fly again and with no real airspeed, it does a dork landing. :x I have also found landing with full spoiler at touch down, seem to stay on the ground better. Dads G1 did not have retracts and when he landing....it landed 3-5 times before staying on the ground. He also did not have spoilers. It was mostly a concept model.
That's about it for quirks or odd handling. Being a wing, it looks a little different in the air and it flies with the nose down, because of no long tail back there.
If I were to build another. I would use the P3 airfoil. I think it looks more like a model airfoil. Mine also has too much reflex, it is stable, but for high speed pass it takes a lot of down elevator. Marske suggested cutting the bottom of the wing and pushing the trailing edge down some. Like with a lot of designs, there are always little things that might make it better.
Mike
Re: GenesisII
Posted: 08 May 2019, 18:24
by Rich vale
Basic spar and wing lay up
