H101 Salto 1/5 th scale
Re: H101 Salto 1/5 th scale
replacement tail constructed from blue foam with balsa veneer. previous version was a bit thick and heavy. saved 60 gms.
nice morning ironing. both wings covered. v tail covered. now thinking if to put film on the fuselage or paint.
getting close to completing the salto. a few pictures attached. spoilers - decider to try a sliding L mechanism as posted on RCGROUPS. next time i might keep it simple They work fine but need a lot of adjustment.
AUW. 2600 gms.
AUW. 2600 gms.
- Attachments
- Sliding L spoiler mechanism
- 11B017C6-D7AD-4E57-9680-97F5F229F9C6.jpeg (22.83 KiB) Viewed 2777 times
- spoiler open
- 0D30D555-3739-4E6C-ABE7-3A07A1325CF1.jpeg (18.99 KiB) Viewed 2777 times
- CCF2FF51-DF8B-430E-A2F1-B7CD83D64B50.jpeg (24.22 KiB) Viewed 2777 times
- with wing tips.
- 6AC93BAC-935A-4228-B7FF-92AC6D5A1AC7.jpeg (36.63 KiB) Viewed 2777 times
finally got around to maiden the Salto in a small gap in the c weather. spent most of the flights adjusting nose weight. tried with and without winglets- with winglets it seemed to perform better. Spoilers are very effective. Had a new frsky g8xr receiver but had poor signal so this shortened the flights.
Barry thanks for the offline suggestions. The poor signal turns out to be a loose antennae on my tx. a few flights on the slope under the belt and a few more improvements needed.
- Andy.Meade
That's a great job to capture the Salto's shape in wood - well done!
it was enjoyable building it and learned a lot on the way. Tempted to improve and do another. Since have built a Petrel from a short kit which gives good ideas for building. Also changed and improved the canopy. Really needs more air time this year.
