H101 Salto 1/5 th scale
andynrose315
Re: H101 Salto 1/5 th scale
Post by andynrose315 »
In the process of sanding the wings - on obechi covered wings i have in the past used ezecote which has given a good finish when covered. Is it worth doing the same with the balsa skinnned wings? Welcome opinions/advise. thanks
andynrose315
Could not resist carpet flying
Trial fit of wings and ailerons.
andynrose315
Nose block added and sanded to shape. Made a hollow inside to include some lead. Trial fitted wings to get a very approx nose weight to balance.
andynrose315
I hate canopies. Say no more
Canopy
Canopy
andynrose315
Evening all - i am even less a fan of canopies now. Since glueing ply around the base of the canopy the ply base has warped so now have 5 mm upstand at the front. everything was fine to that point. I think i will start again, but any suggestions if it could be straightened. the base is 3 mm ply - which has triangular strip to guide the plastic canopy. then i have 1/64 ply as a trim. at best im hoping to save the plastic canopy but before dismantling wanted to see if there are suggestions (other than get someone else to do it for you........ :) )
I've always found it best to fit the canopy with the frame firmly attached to the fuselage?
andynrose315
Chris thanks. Now the moment is why did I not do that in the first place.
Like this:
I use Pacer canopy glue, which dries clear; handy in case of excess application!...
andynrose315
Managed to reconstruct without damaging the canopy. Now straight and fits well. Just waiting for canopy glue to complete. Made some winglets following a posting in RC digest. Now starting covering wings. Will post a few photos later.
andynrose315
Second attempt. Much improved. Still room for improvement. Next.
