Goppingen Micro Wolf Build Log
Yeletah
Post by Yeletah »
Hi,
Relatively new to building, any advice welcome.
I use magnets to build.
Started with the tail plane and rudder, assume I have to sand
The rudder TE down to carry on the taper of the rudder ribs?
Steve
Re: Goppingen Micro Wolf Build Log
For anyone building the little Wolf, please note that the plan was re-drawn by the magazine and shows the rear of the fuselage to be much wider than it should be. What happens is that the sides are drawn together at the rear and glued together with a 2.4mm balsa spacer (mentioned in the plan's annotation). This brings the rear of the fuselage to 12mm in width to match the solid fin...
