This has to be the slowest build that I have ever done. However it has been bucketing rain today so I have managed to spend several hours in the workshop.
The wing joiner boxes and their packing pieces were slid into place and glued up. At the moment there is no easy way for me to check their alignment so I will just have to trust in the laser cutting. The webbing between the spars has been added, 1/16 ply at the wing root and 1/16 balsa the rest of the way to the tip.
The upper leading edge sheeting has been glued and pinned in place. I nearly ran out of pins! I also cut out the slots for the airbrakes and dry – fitted the assembly in place. I have uses 0.225 electric units from “Gliders” as I have found them to be reliable in the past and it saves me messing about with servos and pushrods.
The weather forecast for the next few days is a bit variable so I suspect I will get some more of the upper surface sheeting in place quite soon.
