Ikarus Meteor 1/3
Re: Ikarus Meteor 1/3
Post by Cliff Evans » 05 Nov 2019, 19:36
Dopieman1 wrote:
05 Nov 2019, 19:14
I have a question. Maybe the other Meteor builders or Jillis can help. Its about the end rib of the rudder. How can that rib fit into the slots of the leading edge of that rudder?
I would ask the builder here, he has already made that section of the tailplane. https://www.rcgroups.com/forums/showthr ... r-33/page3
Jilles
Post by Jilles » 06 Nov 2019, 03:32
I am in New Zealand ans cannot access my file. I am sure rib ER8 should have a square hole and round hole in the tail end that I do not see. The square hole should take care of the notches in the spar. The ribs to be split over the square hole so it can be fitted to the spar.
Jilles
Post by Cliff Evans » 06 Nov 2019, 08:53
This is what the rib should look like.
ER8.pdf
(15.66 KiB) Downloaded 44 times
Dopieman1
Post by Dopieman1 » 06 Nov 2019, 22:40
Thanks Jillis and Cliff for your quick reply and support. The rib is not like in the pdf as it is missing the square hole. But no big deal. I did a small modification and cut the rib in two pieces and added a slot. Hope the picture clarifies!
Dopieman1
Post by Dopieman1 » 16 Nov 2019, 08:05
I have received a Fema retract for the Meteor.
Really a nice piece of gear! I will mount it kind of reverse such that the wheel swings up in forward direction just like the real one. Suppose this will not impact on the retraction. There is anyway plenty room for it.
Dopieman1
Post by Dopieman1 » Yesterday, 22:37
Today I prepared the rudders for the covering with 0,4 mm ply. First some balsa filling is to be applied to leading and trailing edge. A bit of a time consuming job.
I decided to apply a tube and wire hinge for the rudder. This to allow for the option to disassemble the rudders when needed.
