SG38 1/4 Scale (Krick)
Ted
Re: SG38 1/4 Scale (Krick)
Post by Ted »
Tail Frame:
Ted
Post by Ted »
Just thinking ahead for covering material, I see you cant get Solartex anymore, can anyone recommend an alternative product?
EDIT: just found some, OK so its going to be either white or natural, is there a difference, its hard to tell from the colour chart on line.
Ted
Post by Ted »
Cliff Evans wrote:
29 Oct 2019, 11:25
This is quicker than Mr Williams builds!! :o :o :o
Truth is I'm currently working on the tail feathers and there appears to be a couple of pieces of balsa missing so it will slow up somewhat until I can source some replacement, no RC shops near me so will have to order online , :( I did like to take a trip out to the RC shop have a look at all the stuff I couldn't afford and carefully hand pick balsa sticks n sheets for best quality, oh well how times change. :?
Ted
Post by Ted »
Tony needs a seat:
Ted
Post by Ted »
Pilot seat and Harness:
The ply seat took a long time to cut out of the 1.5mm ply the shape is barely marked on the plywood face, considering that all the other ply parts have been easily pressed out, I can only assume that there is an issue with the press which is not good considering the cost of the kit, not happy :x
OK finally finished whittling wood and now have a pilot seat for Tony just need to make a harness to keep him on it.
Ted
Post by Ted »
Rudder controls:
Ted
Post by Ted »
Ballast weights:
Ted
Post by Ted »
Rudder:
Ted
Post by Ted »
Stab and Elevator:
Laminating the centre section of plywood and core balsa
Getting there
Ted
Post by Ted »
OK so I've found a Model shop in Cardiff that sells Balsa "Hoora" will drop by over the weekend, pick up a few pieces to complete the tail-plane.
In the meantime, got on with finishing the rudder and covering a few bits, going for natural Solortex.
