1/3 scale Japanese vintage glider Mita type 3
norm
Re: 1/3 scale Japanese vintage glider Mita type 3
Post by norm »
Pilot Seats
The original Mita's pilot seats are composed of a curved wood seat, steel pipe legs and a fabric seat back. Top side of the fabric seat back is wrapped around an aluminum tube and this tube can be moved back and forth for requilining by changing two pins that fasten the tube with the fuselage structure. I simulated them with a curved plywood seat, bamboo rods legs and a fabric back. The aluminum tube is simulated with a balsa rod.
Pilot seats DWG -side view
Pilot seats DWG -top view
Seats
Seats
Seats and Back
Seats and Back
Top view of the Seats
Requilining bar
Requilining bar
河上宣道
norm
Post by norm »
Landing Gear Cover
To prevent air comes in fuselage through the gap around the landing gear, there are two kinds of covers. One is a wheel cover made of plastics and the other is a seal made of fabric. For my model I made the wheel cover with plywood and balsa and the seal with fabric.
DWG
DWG
Wheel Cover
Wheel Cover
Gap seal
Gap seal
View from inside
View from inside
河上宣道
norm
Post by norm »
Miscellaneous Equipments
In addition to the pilot seats and the wheel cover, I added some miscellaneous equippments, such as the shoulder harness, AFT pilot's leg cover, control sticks, tow release knob, spoiler & blake lever, elevator trim lever, cockpit floor and the fuselage access cover.
Although, in actual Mita, the AFT pilot's leg cover,the FWD cockpit floor and the fuselage access cover are all made of aluminum plate, they are made of plywood or hard paper in my model to avoid the radio interference.
Shoulder harness
Shoulder harness
AFT Pilot leg cover
AFT Pilot leg cover
Control Stick and tow release knob etc.
Stick head
Stick head
Cockpit Floor
Cockpit Floor
Fuselage access door
河上宣道
StephenB
Post by StephenB »
Excellent detailing Norm, how did you make the harness and buckles?
norm
Post by norm »
StephenB, the harness is a wooven belt and the buckles are plastic buckle I bought both at a handicraft shop.
河上宣道
norm
Post by norm »
Making the Nose Cowl Wooden Form
The Mita has a nose cowl made from GFRP. In my model I simulated it with glass cloth and epoxy resin. The process to make a FRP part is, 1st: draw a 3D plan, 2nd: make a wooden form, 3rd: make a plaster mold and finally lay up cloth and resin. Attached photos show the 1st and 2nd process I took. The wooden form is made of balsa.
Making 3D DWG by 2D CAD
DWG completed
DWG completed
Parts for the wooden form
Parts assembling
Parts assembling
Inserting filler
Inserting filler
Shaping the form
Shaping the form
Completed wooden form
河上宣道
norm
Post by norm »
Making the nose cowl
A plaster mold was made with the wooden form posted above. It was painted with the mold release agent, then glass cloth was layed up with epoxy resin and cured. One day after the nose FRP cowl appeard. After trimming it was tested to fit with the fuselage structure and the result was perfect.
making the plaster mold
Plaster mold complete
Painting mold release agent
Lay-up
Lay-up
Separation from the mold
Trimmed cowl
Trimmed cowl
Fit test
Fit test
河上宣道
SedB
Post by SedB »
norm wrote:
08 Dec 2019, 12:18
Thank you for this masterclass, looks great so far!
Daniel
norm
Post by norm »
Cliff, I checked the magazine 航空ファン(Aviation Fun) Jan/2020 edition but I could not find any page dealing with Japanese gliders. Could you please provide me the information source? Norm
河上宣道
norm
Post by norm »
SedB, Thank you for your comment. I hope you are enjoying my thread.
河上宣道
