Having flown Motley's version, I have to have one too: a perfect companion for the 1/4 scale Flamingo. My only worry is that having cut out the first parts today as a European, will the subsequent parts still fit tomorrow...?
Re: TYPE 13 PETREL 1/4 SCALE
Posted: 31 Jan 2020, 17:39
by geoff_crew
Don't worry, they're bound to fit up to a 12 months time and by then even you should have it finished
and not only that, if it flies like mine it'll be your greatest creation yet
Geoff
Posted: 02 Feb 2020, 12:04
Being a bit nervous about all the talk of non-alignment and divergence, I bit the bullet and cut out the remaining parts before the 11.00 pm deadline...
Now everything seems to fit perfectly...
P1060250 copy.jpg (49.31 KiB) Viewed 5427 times
P1060254 copy.jpg (53.15 KiB) Viewed 5427 times
Posted: 03 Feb 2020, 06:22
by SedB
The Petrel is a gorgeous glider, I for sure will stay tuned to this build !!
Daniel
Posted: 03 Feb 2020, 08:31
by Trevor
Trouble is, you'll probably have this one finished before the 1/5 scale build I started back in November!
Posted: 03 Feb 2020, 10:24
by VinceC
Trevor, I just checked your website and full marks on an interesting visit. I particularly enjoyed the videos and write up on your Rapide, one of my favourite aircraft of all time
Posted: 03 Feb 2020, 22:30
For monocoque fuselages, the half-shell method of construction is pretty quick, provided you take precautions to keep the fuselage straight. Once the first side has has enough of the 1.5mm ply curved planking applied, the second side comes together very quickly. The small ply plates on F4 transfer the loads from unplanned landings from the thicker ply at the front to the thinner ply at the rear. (Trust me, it works!) The extra longeron is a left-over from the smaller version, and helps to carry the hand-launching loads...
Posted: 06 Feb 2020, 10:11
The short hiatus due to being dragged off to fly yesterday is over... The 1.5mm ply planking at the front is applied in strips of three planks, each being partly cut into the ply and then bent to form a curvature to follow the contour of the fuselage. The important thing is that the fit does not have to be perfect, as the area will be filled on the outside and glassed inside. The result is a very tough and ding-proof front end for the fuselage, adding weight where it counts...
Posted: 07 Feb 2020, 09:40
With the planking completed, time to put a little ecclesiastical plumbum as far forward as possible before applying any filler. Now that all the bracing is in place, the rear of the fuselage is rigid, and well able to cope with the strains of wrapping ply around it...
Posted: 07 Feb 2020, 11:17
by SedB
You build at the speed of light
Since I'm not an experienced builder, I learn a lot from this, so thanks for sharing!!
Looking great so far!
Posted: 07 Feb 2020, 16:45
SedB wrote: ↑07 Feb 2020, 11:17
Seb,
Think time-lapse photography
Posted: 07 Feb 2020, 19:58
Actually, there are hidden benefits to building at the speed of light...Thanks to Einstein's work on Time Dilation Theory, by the time this build is completed I will have aged only a few hours, whereas you lot will be many years older
(In fact, if I could just speed up a little more, I could finish the Petrel before I even started it)
Posted: 08 Feb 2020, 10:11
On this version, I have included a de-bananariser for the tail end in the form of a 3mm lite ply template to sit between the spars and keep the tail end straight...
The filler for the nose needs to be applied in stages, 3 or 4 usually, otherwise gravity will cause bulges to form that will need extra elbow grease to remove...
Posted: 09 Feb 2020, 10:05
Before much more can be done to the fuselage, the rear end needs to be sorted out. I have always found it best to set up the AMT as far as possible, before finally attaching the fin to the fuselage...
Posted: 10 Feb 2020, 10:23
The AMT leading edges are made up from solid balsa, tapered and sanded to shape. The Fin is covered with 0.6mm ply, ready for setting up the AMT
Posted: 11 Feb 2020, 09:35
For builders of the Petrel, the all-moving tail poses a bit of a dilemma... A quick bit of History: there were three Petrels built originally; one crashed, two remain. The best known of the two is Graham Saw's red Petrel, but here's the rub...Sometime during its history, the AMT was substituted with a conventional tailplane, that of a Rhonbussard if I remember correctly. I think most would agree that the AMT is a much more elegant shape than the substitute, so here we have a situation where even the iconic full size is not 'scale'. (The other 'scale' Petrel has been beautifully restored to it's original wood & varnish finish in the USA)
So, I make no apologies for using the original tailplane set up. I hope the diagram makes clear how it works: the tube in the fin hosts the AMT joiner bar, and the bellcrank rotates around the tube in the fin...
Posted: 11 Feb 2020, 11:21
You could give the option on both tailplanes Chris. I know it is more work but.....
Posted: 11 Feb 2020, 12:53
I can offer the drawing from my 3.5 scale version, scaled down, but I'm not building two fuselages...!
Posted: 11 Feb 2020, 14:26
Go on, you know you want to....
Posted: 11 Feb 2020, 15:44
It would only take you 5 mins with your time machine!
Posted: 12 Feb 2020, 00:24
I think you're confusing my Time Machine with my Microwave Bed (8 hours sleep in ten minutes)
Posted: 12 Feb 2020, 07:43
Hmm, I have one of those!
Posted: 12 Feb 2020, 09:05
A quick diversion to the front end to remove the temporary formers and beef up the cockpit aperture edges with 3 x 6mm spruce strip.
Posted: 13 Feb 2020, 09:57
With the cockpit area glassed and the servos fitted, attention now moves to fitting the fin to the fuselage...
Posted: 14 Feb 2020, 09:44
After checking the fit of the fin, it's time to put the rudder together....
Posted: 15 Feb 2020, 11:03
The rudder is completed by adding the solid balsa aerodynamic balance at the front. I've made my usual mistake with the rear ply sheeting by not allowing for the thickness of the fin post...
With the tail feathers completed, the fin can now be epoxied to the fuselage, using a vertical guide in the cockpit to help with alignment...
Posted: 15 Feb 2020, 11:20
Rooky mistake. Once you have built a few you get it right first time.
Posted: 16 Feb 2020, 11:37
The top ply sheeting on the fuselage is 0.6mm ply. Thanks to Motley for pointing out its existence! It seems an excellent compromise between the flimsy .0.4mm ply and the much-harder-to-bend 0.8mm ply. Work on the rear end continues...
Posted: 16 Feb 2020, 12:19
Where are you getting the .6 from Chris.
Posted: 16 Feb 2020, 12:21
SLEC do it...
Posted: 16 Feb 2020, 12:29
Swindon Aircraft Company is a couple of £ cheaper than SLEC if you get the full sheet.
Posted: 17 Feb 2020, 08:03
by john greenfield
Peter Balcombe wrote: ↑16 Feb 2020, 12:29
Not when you add on the postage !!
Posted: 17 Feb 2020, 11:20
Rudder cable guides are from Bowden outers: the stuff from Gliders in nice and straight, and perfect for the job...
Due the sharpish curve at the rear, the lower ply sheeting is glued in the middle first, then, when the PVA has dried, the lower edges simultaneously glued in place with tensioned masking tape...
Posted: 18 Feb 2020, 08:55
A quick look at the root and tip wing ribs shows just how tapered the Petrel wings are...! In its earliest stage, the wing is assembled flat on the board before being hoisted up on to the supports in order to add the top spar. The gentle angle of the gull break means that the 5mm sq spars aren't overly distressed at being forced into the correct angle.
Posted: 18 Feb 2020, 10:47
by SedB
Nice progress Chris!
The ribs (before assembly) look very fragile to me, guess I'd manage to break while testfitting!
Daniel
Posted: 19 Feb 2020, 11:39
Med/hard 2.4mm balsa, Dan...strong enough!
With the basic wing structure taped to the gull supports, the top spar can be added, as well as the 0.8mm ply reinforcements to the rear of the ribs...
Posted: 20 Feb 2020, 11:47
The wing joiner boxes are 16mm & 13mm respectively. The all-important sub spar is let in against the ply web plates on the front of the main spar (10 minute job per spar)
The sheeting will be 1.5mm hard balsa..
Posted: 21 Feb 2020, 11:50
With both sub spars added, the lower sheeting can be glued in place. Thanks to the gentle gull angle, this can be achieved in one piece...
Posted: 22 Feb 2020, 09:05
In a similar manner to the sub spars, the diagonal sheeting supports at the root are retro-fitted. The wing is weighed down on its jigging supports for the addition of the top sheeting. This, too, can be fitted in one piece, although it will put up a bit of a fight! After clamping the rear of the sheeting to the spar, masking tape at the front will force the sheeting into submission. As a precaution, the inner panel TE is clamped to a straight edge to preserve its integrity...
Posted: 23 Feb 2020, 11:35
Time to close off the wing roots, now...BTW the long sanding block is a very useful tool: this one is simply a length of 6mm balsa sheet with 40 grit strips glued to both sides. This, and the 80 grit version, are good for many jobs, especially where a straight edge is required...
Posted: 24 Feb 2020, 09:49
There'a purpose to letting all the brass tubes protrude from the wing roots... To make up the wing root fairing liners for the fuselage, a 1.5mm ply blank is pressed up against the wing root in order to make an impression in the strategically placed double piece of masking tape... This is then cut out and the blank placed over the protruding wing joiner box and the process repeated for the incidence peg tube. The blank can then be offered up again to the wing root and the wing profile drawn on it before cutting it to shape...(Takes longer to explain than to actually do!)
Posted: 25 Feb 2020, 09:41
Now it's time for the tricky bit..attaching the wings to the fuselage... they have to be correctly aligned in 3 axis: parallel to the AMT, at right angles to the fuselage and set at the correct angle of attack: the pics should tell the story...
Posted: 26 Feb 2020, 09:58
Once the problems of alignment have been sorted, the brass box can be glued in place, thus allowing the ends to be trimmed off, prior to offering up the wings and finalising the wing root fairings...
Posted: 27 Feb 2020, 09:41
Scrap TE stock is ideal for filling in the spaces in the wing root fairings. A final application of thin CA, and it's time to start adding the filler...
Posted: 28 Feb 2020, 09:59
With the initial application of filler blocked back, the fit of the wings can be finalised. Always a good idea to separate the wings before the filler has fully cured
Posted: 29 Feb 2020, 10:02
Having finished off the sheeting of the fuselage, it's time to make up the ailerons. For simplicity and extra efficiency, these are top-hinged and sealed underneath with Mylar strip. Built flat on the board, it's important to ensure the LE is flush to the board when adding the ribs. The whole thing can be built with CA, and goes together surprisingly quickly...
Posted: 01 Mar 2020, 15:14
Next up: the spoilers...
Posted: 02 Mar 2020, 15:49
Moving on to the canopy, the side rails are made up from 2 lams of 3 x 6mm spruce strip, held to the side of the fuz in order to take up the curve, and packed out to allow for spring-back... The frame is made up inside the cockpit aperture. 7 sets of 10mm diameter magnets have been used this time around, as the 4 sets in the Flamingo didn't seem all that secure...
Posted: 03 Mar 2020, 09:43
With the instrument panel made up, the canopy can now be fitted...
Posted: 04 Mar 2020, 11:22
That's it for the Petrel airframe, then: this channel will now observe radio silence as the covering & painting commences...
Posted: 04 Mar 2020, 12:13
by Geoff Pearce
looking nice, once again Criss
what colour pink?
Posted: 04 Mar 2020, 12:14
Must be time for "Incoming" then???
Posted: 04 Mar 2020, 18:41
by Ray Watts
That's 4 1/2 weeks from start of cutting out, to ready for covering, of a quarter scale all built up woodie. You are unbelievable Chris.
Posted: 04 Mar 2020, 19:14
Ray, I call it...'retirement'
Posted: 04 Mar 2020, 21:16
by Trevor
chris williams wrote: ↑04 Mar 2020, 19:14
Well, I’ve been retired for 20 years but I’m 4 months in and counting with my build of the 1/5 version - and I started with Cliff’s laser-cut parts!
Posted: 13 Mar 2020, 17:30
Mission-ready...
Posted: 13 Mar 2020, 18:12
Very nice Chris.
Ready in time for the March White Sheet bash - weather permitting
Posted: 13 Mar 2020, 19:26
by Trevor
Very pretty. Now I know where Hobbyking’s stock of clear covering went!
Posted: 13 Mar 2020, 20:24
by SedB
My god, this Petrel looks gorgeous!!
Looks even bigger than 1/4th size! I still can't believe how quick this one came together !!
Can I already wish you good luck for the maiden!?
Daniel
Posted: 13 Mar 2020, 22:14
by VinceC
Nice one Chris
Posted: 17 Mar 2020, 11:40
I consider myself fortunate indeed to have been able to get a last-minute maiden of the Petrel at CMFC yesterday before Johnson's Mass-Geezer-House-Arrest edict kicked in... Just a few clicks of up-trim were required, the model unsurprisingly a clone of Motley's version...
Posted: 17 Mar 2020, 11:48
by SedB
!!GORGEOUS!!
Lovely pics of this first flight!!
Daniel
Posted: 17 Mar 2020, 12:09
Again Chris, B****y lovely!
Posted: 17 Mar 2020, 15:19
by Geoff Pearce
Nice pics again, your worth it!
I just can't think what for
Posted: 17 Mar 2020, 19:09
by Jolly Roger
Well done Chris. Fred would be proud!
A couple more Petrels and you'll have matched your Minimoa tally?
Posted: 19 Mar 2020, 15:07
by StephenB
Lovely!
Are people really not allowed out for some fresh air on a hillside??
C.C. All BMFA Members
Model flying and the COVID-19 Virus - News Release 17-3-2020
We have been monitoring the current situation carefully and have been awaiting clear guidance from the Government before making decisions relating to general model flying and BMFA Model flying events, contests and roadshows.
It is clear that the COVID-19 situation is developing rapidly in the UK and members should keep themselves updated on current government and NHS advice. Please see https://www.gov.uk/government/topical-e ... t-response for the latest information.
In general terms model flying represents a low risk activity due to the predominantly outdoor nature of the activity and the opportunity to maintain inter-personal separation.
At this time, and subject to any updated government advice/instruction, for those who are not unwell there is little reason to curtail outdoor model flying activities in the club environment. The well-being benefits provided by model flying should be balanced by the potential risk and NHS precautions should be followed.
While there is little reason to curtail normal outdoor flying activities, clubs should consider what action to take regarding indoor club meetings and any proposed or scheduled larger events they have planned which, under present guidance, may have to be cancelled or postponed.
BMFA Organised events, contests and roadshows
The BMFA is currently reviewing the status of scheduled events. Several events/contests are already subject to cancellation including the Swapmeet at BMFA Buckminster, the ASRC Roadshows and the Free Flight Nationals. Planning for the Power Nationals in August is continuing on the assumption that it will be going ahead, but this will be kept under review.
Members should keep checking the Contest and Event calendar on the BMFA website for status updates on specific contests and events. Should contest/event organisers wish to amend/update their entries on the BMFA Calendar, please contact the office or complete the online request form here: https://e-forms.bmfa.org/event-amend.
BMFA Office
The BMFA Office functions will remain in operation, though the office may not be physically staffed to the usual level and we regret that for the time being we are no longer able to welcome visits from BMFA Members. We have measures in place to ensure that support for members and clubs continues. Please use admin@bmfa.org as the primary means of contact.
Important note:- Please stay at home and do not attend flying sessions, events, contests or meetings if:
you have been in contact with a COVID-19 patient
you are unwell, with a high temperature and/or a new continuous cough
you have serious underlying health issues
The Society of Model Aeronautical Engineers Limited T/A The British Model Flying Association
A company limited by guarantee. Registered in England Number 457067
Registered office Chacksfield House, 31 St Andrew's Road, Leicester, LE2 8RE
Posted: 19 Mar 2020, 18:56
Thanks Robbie.
Posted: 15 Apr 2020, 21:21
by SedB
Chris, may I ask what you use for covering? Is that natural Solartex, or maybe Oratex antique?
Thanks!
Daniel
Posted: 15 Apr 2020, 21:48
by Trevor
I’m pretty sure it’s HobbyKing’s clear polyester film (like Oracover). Good luck on finding any in stock though.
Posted: 16 Apr 2020, 00:11
Yes, it's HK's new matt clear film...the reason you can't buy any at the moment is because I bought the bloomin' lot!
Posted: 16 Apr 2020, 09:03
by VinceC
Was it you that bought all the toilet rolls as well?
Posted: 16 Apr 2020, 09:34
Update: HK's EU warehouse is now showing the film back in stock. Also, the Corona wing servos. No toilet rolls. Has anyone noticed that the HItec wing servos seem to be re-badged Corona servos at the three times the price?
Posted: 16 Apr 2020, 11:15
by SedB
Thanks gents!!
Daniel
Posted: 17 Apr 2020, 09:03
by andynrose315
Hi Chris - i now have a 1/5 scale Petrel kit and slowly progressing. Not sure what the policy is here about posting - thought about a separate thread but not going to compete or be ashamed by my own abilities! Anyway have a question with the AMT, which is probably as relevant. Just been trying to dry fit one side of the AMT and have brain freeze with the best way to assemble the brass tube that fits inside brass tube support ply parts and maintain alignment. easy enough dry fitting but when would the tube be glued in? There is some play between the tube and support. Andy
Posted: 17 Apr 2020, 09:46
First of all, Andy, have you had the full set of build pics from me?
Posted: 17 Apr 2020, 10:35
by andynrose315
Hi Chris - no just been going on those in this thread plus Trevor Hewsons thread
Posted: 17 Apr 2020, 11:40
OK, let me have your email address, and I'll send 'em to you?
OK, job done...if you still have questions, fire away...
Posted: 27 Apr 2020, 08:15
by andynrose315
Chris - many thanks for the pictures and parts. Much appreciated. Moving steadily forward - AMT was not so bad after all! I am now at the stage of adding the ply to the top of the fuselage. Made a template, - now thinking best way of gluing and holding in place. are the spring clamps the best way- looking at your photos you have Uk stock of spring clamps it seems. I dont have as many so unfortunately but could use masking tape.Presume best to fit in one piece in one go. Any advice would be appreciated........Andy
Posted: 27 Apr 2020, 10:08
Andy, a bit of pre-bending always goes a long way... Tape it into a curve; wet it up, and iron it dry... (You won't get that much of a curve but every little helps) Tape is good, of course, but in my pre-clamp days I always found it beneficial to raid the missus's store of clothes pegs.
Posted: 27 Apr 2020, 17:08
by andynrose315
Chris. okay. went with the clothes pegs with the help of a hardwood strip. Ply was prebent as recommended. Glad adhesive is not fast setting. Excuse the messy table. Got there in the end. Thought is worse than putting it together. Andy.
Posted: 27 Apr 2020, 17:35
From my (very) limited experience with doing this, I drill a 2mm hole through the centre of the ply at each end, into the former , and put a cocktail stick in when gluing. That stops the ply sliding around on the glue, while you are clamping it down.
Hope that helps.
Posted: 27 Apr 2020, 19:42
Also, for stubborn bits, one or two small screws can be helpful...
Posted: 28 Apr 2020, 08:57
by john greenfield
Alternatively, you could use the PVA and hot iron method. See links to video tutorial below. The video shows wing sheeting around a much smaller radius than a fuselage but the technique is exactly the same but start in the middle of the sheet and attach to a longeron and then work down both sides.
thank you for the guidance. Managed in the most with 0.8mm ply. dropped to 0.6 in the tail. i am now starting the wings and have a question when the sub leading edge is applied and if it is split at the gull break. Chris the photos sent through suggest it’s fitted when on the flat, then lifted onto the supports. can’t quite make out if the sub LE is in two at that point. i.e joined following lifting on to the supports. Andy
Posted: 05 May 2020, 20:39
I can't either, and I certainly can't remember! Cut the LE with a pair of scissors at the break (having not applied any glue to the front of that rib) before lifting on to the jigging supports and re-glue...?
Anyone for a shop where I can get both these brass boxes and a the steel joiner at the same place? Here in the Netherlands I find it difficult to find a shop who sell both online.
Daniel
Posted: 06 May 2020, 21:40
SedB, the 2 sizes are the outside dimensions of the brass tubes that hold 12x2mm & 15x2mm steel joiner strips.
The brass tubes are 13x3 & 16x3mm respectively.
Gliders Distribution in the U K stock both (sold as 1m lengths normally, but I don’t know if they are able to ship to the Netherlands, or maybe there is a supplier on your side of the English Channel.
Posted: 06 May 2020, 22:19
The steel and brass are products supplied by Aeronaut as I understand it... They must supply to the continent
. i’m working my way through the second wing of the 1/5 build. i have just noticed that there is balsa sheet spanning one rib each side of the gull break in this build. This does not appear on the 1/5 plan. Now thinking if i should sheet this area too as it probably stiffens the structure. Any recommendations?
Posted: 02 Jun 2020, 07:35
by Trevor
My recommendation would be yes. As well as strengthening the structure, the covering will look neater too.
Hmmm, looks like an omission at the magazine end: my original drawing shows the gull section fully sheeted. Have I sent you the complete build pic sequence: it shows clearly enough on there?
Posted: 02 Jun 2020, 13:12
by andynrose315
Chris thanks will add the sheeting. you are correct the photos do show this sheeting.
Posted: 02 Jun 2020, 18:12
by andynrose315
Trevor wrote: ↑02 Jun 2020, 07:35
Chris/Trevor
My current plan is to use heat covering for wings and fuselage. but
not really used car filler before. is it best painted or does it take covering ok? i have tested a small area and seems to adhere but also had to be careful as the heat appeared to lift the filler where it was really thin. just wondering about longer term issues.
thanks areas most affected are the nose and wing fairings.
Andy
Posted: 16 Jun 2020, 20:24
As you know, Andy, I cover my fuselages with 'Tex and 2K prime the areas you mention. 'Tex needs a higher temperature than film, and that doesn't affect the filler, but for further piece of mind, thin CA over the edges should seal it all off...
Having said that, Trev's filmed fuz looks the Dog's Danglers
Posted: 17 Jun 2020, 08:30
by Trevor
But the fuselage on my 1/5 Petrel is skinned with balsa not ply, so I've never used the car filler. The lightweight filler that I use in cracks and dents takes film okay over small areas but, as you say, I'd be wary of larger areas for fear of the filler lifting. I suspect the car body filler has much stronger cohesion than these lightweight fillers though, so may be okay.
Posted: 06 Jul 2020, 19:55
by andynrose315
just about finished now and soon be ready to fly. one last highly technical question - any recommendations for the rubber bands or other elastic to hold the wings?
Posted: 06 Jul 2020, 20:11
If you Google No 63 Rubber Bands, I've been using these for years...
Posted: 08 Jul 2020, 10:23
Finally, finally, a decent day's flying at White Sheet. The Petrel, along with other Slope Virgins, like Trev's 5th scale Petrel and my Zugvogel, had a merry old time... (Also, the little Wolf slopeside in it's new livery for the 1st time)
Posted: 19 Feb 2021, 11:35
Also, for those who enjoy Scroll Saw Therapy, the parts are available from me in PDF form, all ready to print out in an A4 printer. (Note: always check the printout outs against the plan)
Posted: 27 Jun 2021, 08:29
...and finally:
Posted: 05 Aug 2021, 23:37
by Alex Tankink
john greenfield wrote: ↑28 Apr 2020, 08:57
Tried to follow the links to learn about the PVA method.
The links don’t work / unavailable
Any other tutorials you guys can point me towards?
Alex
Posted: 06 Aug 2021, 08:28
Alex,
Link works for me in the U.K.
Try going the long way around by searching for the ‘Ghost Squadron Model Aircraft’ team to see if you can find their main website, then click on the Constructional video & tips button on LH side of main page once you get in.
Good luck,
Posted: 06 Aug 2021, 08:31
I cannot get to them either! /Have spoken to John about it.
Posted: 06 Aug 2021, 08:38
Ah yes, although I can get to videos page, I can’t actually get a video to run either
I’m sure John will sort it out before long.
Re: TYPE 13 PETREL 1/4 SCALE**
Posted: 06 Aug 2021, 09:27
by john greenfield
Thanks for letting me know about the video problem. Not sure what the problem is but we are working on it and hopefully will have it fixed soon.
Posted: 18 Aug 2021, 21:04
by andynrose315
sorry gate crashing the larger sibling but finally got round to maidening my Petrel. Video is not great but linked below.
Posted: 15 Dec 2021, 20:45
Well done Andy: looks a lot like WSA's Horses' slope?
Posted: 15 Dec 2021, 20:46
Time now for a 1/4 scale version of the red Petrel...
Posted: 18 Dec 2021, 20:27
by andynrose315
chris williams wrote: ↑15 Dec 2021, 20:45
Hi Chris. yes horses. Also tried winklebury on better weather conditions. Really like the model. thanks for sharing!!
Posted: 22 Feb 2022, 12:51
The 1/4 scale version of the 'Red' Petrel is maiden-ready...
Posted: 16 Mar 2022, 10:04
Proof of the pud...!
Posted: 18 Mar 2022, 17:13
by MartinE
Looks fabulous Chris.
Annoyingly, I'm on a weekend away, with a view of White sheet- but the winds in the wrong direction
