The canopy glazing tool is now ready to be sent off to Sarik to have a couple of canopies pulled. The mottled appearance is due to me making minor adjustments to the shape by judicious skims of filler followed by careful use of various grades of wet and dry paper. I spent a lot of time going over it filling tiny pin holes. Final sanding with 400/800/1200 wet and dry paper has given a nice smooth finish. I suspect that there will probably be a few minor imperfections in the final pulled canopy but as they say “at 500 ft who will ever notice”.
I have also received a very nice 3D printed instrument panel from Cliff Evans (thanks Cliff) which will adorn the finished cockpit.
Brian. :) :) :)
The completed tool ready for pulling the glazing.
3D printed panel from Cliff.
I have now started the build of the right hand wing. The completed left hand wing was built inverted on the plan of the right hand wing therefore logically the right hand wing is built inverted over the plan for the left hand wing. Straightforward right? No Left? Confusing isn’t it?
Brian. :D :D :D
R/H hand wing panel built over the L/H wing plan!!!
terry white
Post by terry white »
Looking good Brian, :D
Thanks Terry, its nice to be back working with wood once again rather than messing about with foam, glass and filler.
Brian. :?
The build of the right wing continues. The joiner reinforcement, bottom main spar, the ply and balsa webbing and the balsa false leading edge have all been added. I have now added the underside, leading edge sheeting. No real dramas and I even managed to arrange the pins tastefully.
On the other bench I have the rear underside sheeting cut, scarf joined and glue drying ready to be stuck in place once the aliphatic has set on the front.
Right wing progressing.
This afternoon I tackled the bit that I dread when I am building wings – fettling the joiners. I fitted the main joiner into the completed left wing and the right wing shell before mounting them on jigs that would hold them both at the same angle of incidence. Then the right hand incidence peg tube was slipped onto the incidence dowel. Low and behold – it fitted perfectly! Well actually no it didn’t. :x :x :x
There then followed a good half hour of sanding, filing, paring back and cursing before I finally got everything fitting and sitting square. The incidence looks right, the angles all look right and it comes apart with only a little persuasion. :)
I took it outside my workshop to show my wife who was working in the garden. She saw it propped up against my workshop and was appalled by the size – so I must have got it right then! :D :D :D :D :D :D
The next job is to build all the gubbins into the right hand shell before finishing the sheeting.
Left and right wings introduced to each other.
Centre section and joiners.
Great news - my wife was appalled.
Ray Watts
Post by Ray Watts »
You clearly need to go to third scale then Brian to keep her satisfied :lol:
Ray
It's always calmer indoors :D
I tried that a couple of times Ray and earned myself the really grumpy treatment.
Brian. :D :D :D
Both wings are now fully sheeted and sanded and have the root ribs fitted. The next job will be to cover the wings and fuselage with 25gm/m2 glass cloth and epoxy resin. However before that I took the opportunity to assemble all the bits to check out the fit and see what the finished machine would look like.
I have to say that I am quite happy with it so far!
Brian. :D
The embryonic B4.
The embryonic B4.
I started on the covering of the airframe this afternoon. Everything on the airframe is being covered in glass cloth except from the tailplane and elevator which have been covered in Oracover previously. The glass cloth I am using is plain weave 25 gm/m2 cloth from East Coast Fibreglass which I have found to be very good in the past. I am using the EL2 Epoxy Laminating Resin from Easy Composites which goes on very nicely and usually sets nice and crisp within 24 hours. I always mix too much resin on the first batch and I have managed to cover half the fuselage, half the fin, half the rudder and the top side of both ailerons and still had some resin left in the pot.
Fuselage, rudder and ailerons all covered in wet glass.
